Old 03-16-2006, 09:14 PM   #11
Isphius
Isphius's Avatar
and what is the best way to lower compression? wouldnt a thicker gasket be weaker? the only thing i can think of is shorter pistons and/or con rods, but where can you get those?
Old 04-08-2006, 03:49 AM   #12
Isphius
Isphius's Avatar
Has anyone ever but a delorto or webber carb set up on a supra? youd only need 255 cfms for 6k rpms and at 80 % volumetric effciency. Maybe more or less. Youd just have to make your own manifold for it. I would only do that if i had an expensive fuel injection problem thou, like a fried coil or ecu. And you would also need a vaccum advance distributor or some kind of controler for the electric one
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
Boost issue.. Kinda... 2JZEFINI-17 MKIII Supra 1 11-12-2006 02:54 PM
