-   -   Code 52 Wire? (http://www.toyota-supra.info/forums/mkiii-supra/19212-code-52-wire.html)
STR 06-02-2011 02:15 PM
Code 52 Wire?
So my code 52 is only coming on when its cold now. think that would be the knock sensor wire now?
cre 06-04-2011 06:41 PM
That could happen with any of the three components. In order of likeliness: wiring; sensor; ECU
If you can get a used sensor for very cheap try that firs as it's low labor. The rewire is usually less expensive though but much more labor intensive. I would wait on swapping the ECU as that is very seldom what's to blame.
STR 06-05-2011 03:05 PM
i was going to try the sensors them selves first until the last owner (friend of mine) said he just replaced them not too long ago.
