Old 07-31-2011, 04:54 PM   #1
my89Supra
my89Supra is on a distinguished road
Default Stripped Exhaust studs
Looking for best solution to repair stripped exhaust studs. I see DriftMotion sells a helicoil repair kit and another company called Time-sert sells thread repair inserts.
Anyone have experience with either of these or have an alternate suggestion ?
Also, is it possible to remove the exhaust manifold with the turbo intact (disconnecting oil and water lines of course).
Thanks for the help.
my89Supra is offline   Reply With Quote
Old 07-31-2011, 05:45 PM   #2
El Supracabras
El Supracabras's Avatar
Yes they work, but the material on the head is sometimes beyond being able to hold even a heli-coil. The drift motion kit is nice because they did the shopping for you. You could buy it yourself all separately but I doubt you'd save much. There really is no other alternative beside replacing the head.
You prolly could leave the turbo on but I would take it off and give it a good cleaning and inspection while it's easy.
Old 07-31-2011, 06:44 PM   #3
my89Supra
Default Exhaust studs
Thanks for the feedback.
The DriftMotion kit includes oversized studs so I should be okay there. I'll probably see about rebuilding the turbo if only to replace the oil seals as the car burns oil when the turbo kicks in hard. Probably a good idea to play it safe and have the exhaust manifold shaved too.
Thanks again for your help.
Old 07-31-2011, 06:47 PM   #4
907mge
907mge's Avatar
http://cjsupra.kendra.com/Helicoil.html
Old 07-31-2011, 06:54 PM   #5
my89Supra
Fantastic, thanks!
Old 08-01-2011, 12:52 PM   #6
Green7mgte
Supra Forum Moderator
IIRC the kit offers acouple different sizes? maybe not, it's been awhile since I read on the subject. Altho I do remember the guy who makes them said he only put a 5 dollar mark up on it. or you could do what I did for a stripped exhaust bolt.. concrete lag bolts. what? don't look at me like that. ....
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Tags
driftmotion, exhaust studs, stripped studs, time-serts
stripped out exhaust manifold stud robertsws MKIII Supra 3 07-31-2011 04:38 PM
Exhaust system & components Krem MKIII Supra 6 05-27-2010 12:35 PM
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
