Old 05-25-2011, 03:23 PM   #1
STR
STR is on a distinguished road
Default HKS FCD Fuel Cut Controllers?
anybody have/used this mod? pro/cons?
http://www.horsepowerfreaks.com/part...llers/FCD/1917
STR is offline   Reply With Quote
Old 05-25-2011, 07:02 PM   #2
916MKIIIx2
Thats pretty pricey, I think you could get the same effect and then some with a good air fuel controller. Of course the Air/Fuel controller will cost about a hundred more but I think its a better buy in the long run, especially if you're upping the boost. Simply raising the fuel cut level of the engine just sounds dangerous, more so for track only applications if any.
Old 05-25-2011, 07:24 PM   #3
El Supracabras
El Supracabras's Avatar
Do they make a HGD? That might be more useful. Pros: car will be faster Cons: not for long. The money is better spent elsewhere, besides aren't those things from the 90's anyway?
Old 05-25-2011, 09:20 PM   #4
STR
ok so what's a good Air/Fuel controller?
Old 05-25-2011, 09:47 PM   #5
916MKIIIx2
There are a lot of good ones out there, try searching for Air/Fuel Controller in the search menu for the forum. But if I might ask what exactly are you going for in your car?
Old 05-25-2011, 10:41 PM   #6
STR
with the 3" down pipe i have the boost is now higher then stock, 8-9 psi, and i cant give her WOT without the car hesitating. i can feather the throttle up and down but if i keep it floored she cuts power.
Old 05-25-2011, 10:47 PM   #7
916MKIIIx2
Have you checked to make sure you didn't accidently unplug a vacuum line from the wastegate?
Old 05-25-2011, 11:52 PM   #8
El Supracabras
If you are only hitting 8-9 psi it might not be fuel cut. I think it kicks in at a little higher pressure. Are you using an aftermarket boost gauge? The stock one isn't very accurate especially above 8psi.
Old 05-26-2011, 04:54 AM   #9
STR
yes after market gauge. old one replaced with volt
Old 05-26-2011, 01:27 PM   #10
El Supracabras
When you keep it floored it cuts out? In gear? Have you checked for any codes?
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
