-   -   TPS code 41... (http://www.toyota-supra.info/forums/mkiii-supra/19039-tps-code-41-a.html)
Cyberguy1992 04-26-2011 08:14 PM
TPS code 41...
Just put new TPS in about 2 summers ago... I'm guessing its the VTA wire from the TPS causes code 41 cause I don't code 51(Idle Signal)..... if I bring VC and E2 from the Air sensor i get get both codes for the throttle sensor 51 and 41 the way i have it now is I just brought E2 from the Air flow sensor so i only have code 41.... how do I get rid of code 41.. I though VTA just goes strait from the throttle sensor to the ECU.... could i have hooked something up wrong in the past and fried the throttle sensor? I'm so confused...
