Old 04-20-2011, 08:46 PM   #1
OdysseusOnWheels
OdysseusOnWheels's Avatar
OdysseusOnWheels is on a distinguished road
Default Steering Wheel Replacement
Hello world!
Is the 1989 MK3 steering wheel a direct replacement for the pre-89 steering wheels? Will the cruise control work properly?
Thanks!
OdysseusOnWheels
1986.5 Red Pearl Non-Turbo
OdysseusOnWheels is offline   Reply With Quote
Old 04-20-2011, 09:04 PM   #2
I'll keep it simple.... No.
Old 04-20-2011, 10:30 PM   #3
OdysseusOnWheels
Cool...so how far back on the electronics do you have to go to make the swap work?
OdysseusOnWheels
Old 04-21-2011, 09:05 PM   #4
At least the column harness, I don't recall if there were more changes beyond that. There definitely are if you want to use the 89+ gauge cluster's cruise indicator and you may need to delete the pre89's primary control switch... you'll be needing a 89+ column too.
Just look at the wiring diagrams, there are plenty of links to them here, Cygnusx1's if for a '90 or '91. The pre89 you'll need to download in PDF format. I think the turboninja website is still a good source.
Tags
mkiii, steering, wheel
Momo steering wheel , working horn and returning indicator stalk Gunnar MKIII Supra 0 03-28-2010 09:41 AM
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
Aftermarket steering wheel RTZ MKIII Supra 10 02-07-2008 08:44 AM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
