Old 04-12-2011, 11:12 AM   #1
cfurlan
cfurlan is on a distinguished road
Default What is the best way to clean grime off of head?
I'm installing a new head gasket but the head is covered in oil and grease so I want to get it all cleaned off. I have a gallon of purple power and brake clean, or I can pick something else up. What would be the best way?
cfurlan is offline   Reply With Quote
Old 04-12-2011, 12:27 PM   #2
scothbright pad and carb cleaner. brake part cleaner w/e. and as soft plastic paint scrapper. try to stay away from things that will scratch or distort the surface in anyway
Old 04-12-2011, 12:50 PM   #3
Travis89Turbo
Travis89Turbo's Avatar
Pay ten bucks and take it to a machine shop for a hot tank bath!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 04-13-2011, 01:27 AM   #4
Sonyps307
You should have the head checked for warpage at a shop anyways And they should clean it also.
Old 04-13-2011, 06:41 PM   #5
87hilux7mge
87hilux7mge's Avatar
do what i did, 55 gallon drum and a campfire lol. but seriously, have the head surface checked at a shop. i cant recommend having a hot tank job done, as when they did mine, it didnt take SHIZ off. i got it back, ran it thru my dishwasher, re-checked my surface, and it was ready for paint. u can check my album and see how dirty the head was b4 and how it looks now.
the only thing the the machine shop actually did, was machine the head surface, it was like 26 bux for me (add in 10 bux for them to "clean" it)
degreaser will work great, just put it in a spray bottle, or better yet, do a hot water mix in a bucket, then let it sit, then hose it off. guess ud have to disassemble the head tho..
another mix that works great is the degreaser mixed 2:1 with bleach. that will literally take paint off a car. but be sure to have a mask and be in a WELL ventilated area if you like your lungs. spray that on, and hose it off. prolly will take 1 pass.
good luck!
Old 04-13-2011, 07:01 PM   #6
Ranma
Ranma's Avatar
Also be sure to have it pressure checked. The owner before me cracked the head somehow. It took the mechanic a long time to find the leak. Well all of the seals did need to be changed Now he does not leak on my garage floor
Head skim requirement? MA70-3.0GT MKIII Supra 11 12-15-2009 06:03 PM
