Old 04-08-2011, 02:23 AM   #1
supraquest
supraquest is on a distinguished road
Default antifreeze problem
Hi guys got a wierd one i have a 88 7mgte with a prob it is fresh rebuilt head all redone block all redone cometic mls head gasket,arp studs,62-1trim turbo only set at low boost 10 psi till motor is broke in. problem is it blows antifreeze out of over flow tank when i get on it a little bit but no over heat or leaks of any sort did leakdown test with no results????
supraquest is offline   Reply With Quote
Old 04-08-2011, 05:36 AM   #2
ochowdero
your overflow meter is bad i bet...
mine did that, then finally over heated..
so dont be too hard...til its fixed
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 04-08-2011, 10:48 AM   #3
supraquest
thanks but dont believe that is it the car is not stock and has no flow meter.
Old 04-08-2011, 08:44 PM   #4
Green7mgte
Supra Forum Moderator
1.. quite topping off your rad.
2. check your rad cap.
3. whats the pressure on your rad cap
if you fill your radiator to full, when it expands itl be forced to dump.
when coolant warms it expands and pressed against the spring in the rad cap which opens it up. faulty cap ='s dump.
Filling the rad up to the top row is fine. when cool there should be about 2 inches or so below the neck.
If your puking green then you are overheating and that's the pressures escape rout.
Id replace the thermostat and the rad cap to be safe. Then give it a good Burping.
help me help you.. Do you have heat?
worse case scenario you have a blocked rad creating a flow restriction exudes in a light overheat. Not seen on the temp gauge but is for the ecu.
best case scenario is you just have a bad rad cap. won't hold pressure and just dumps. check that first man Good Luck
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-10-2011, 03:38 PM   #5
supraquest
its all new radiator cap and thermostat all working properly plus the over flow tank is empty when i start out and it filled it up plus pushed it out but i believe its the head gasket cuz i retorqued the head and it seems to be ok now thanks for the advice.
Old 04-11-2011, 12:46 AM   #6
Green7mgte
well I was leaving out the headgasket cause you said it was a new one.. never thought to ask "did you re torque it" after a couple cool down cycles. like were suposto.
glad it worked out for you. take care.
Supra FAQ
Supra MKIII FAQ
Major Problem Antifreeze everywhere g_rizzo MKIII Supra 1 03-31-2011 05:14 AM
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
