-   -   how can i get more hp help (http://www.toyota-supra.info/forums/mkiii-supra/18912-how-can-i-get-more-hp-help.html)
graywolf1969 04-04-2011 04:44 PM
How can i get more hp out of my stock 7mgte with out tearing my engine up
ochowdero 04-04-2011 08:52 PM
theres a faq on how to get cheap but quick hp,,
alot of people will tell you to do an engine rebuild with a thicker/metal head gasket.. increase your turbo psi and/or bigger turbo with like 8 psi.. full exhaust w/out the resonator, and then straight piping from a cat back to a aftermarket exhaust...HKS dual tip is actually the only i know of right now that increases the supra hp, and is proven on the dyno.. but this one is a quiet rumble... and also im sure there is other exhaust tips that increase hp but idk...
as for exhaust headers. i heard that theres no point, but idkk...
bigger intercooler, lexus afm, and 550cc injecters to compensate for the bigger afm.. hgiher boost! haha, but gotta do alot of work so you dont blow your engine..
theres more, just look at the faqs
graywolf1969 04-04-2011 09:26 PM
The engine in this car is a jdm 7mgte it now has 37,089mi on it and i cant read all of what you typed something is blocking most of what you typed and what about a manual boot controller is that ok to put one of those on there. If you can message me on here
Green7mgte 04-04-2011 11:03 PM
manual boost controller. It is so you can increase the lbs of boost. Not recomended to fiddle with it if you are totally green to tubro cars.
Check the Faq there is a good post about this. as the above poster stated.
