Old 03-30-2011, 05:35 AM   #1
doyle.iam
doyle.iam is on a distinguished road
Unhappy differential repair or swap
I'm new to this forum: where to buy ring and pinion gears and limited slip differential clutch rebuild kits? my 86 supra has a chevy 350 and automatic turbo 350 trans.... are there any good differential swaps like 8.8 ford or corvette set up?
doyle.iam is offline   Reply With Quote
Old 03-30-2011, 07:02 PM   #2
There are no easy swaps nor any kits that I know of to do so. I have seen a couple owners who've had custom rear subframes mad or the stock one modified to fit domestic housings... While I like the options it opens up the cost and effort isn't worth it to me; The stock differential is a beast and can take a lot more than your engine is likely to be giving it. You'll most likely need to source the shims and any other components from Toyota. The only part I've heard of anyone going elsewhere for was a custom made crush sleeve for preload purposes, IIRC.
Tags
lsd clutch kit, ring & pinion, swaping differentials
7M-GTE. Repair or swap OsiowyMK3 MKIII Supra 0 08-14-2009 01:07 AM
differential swap or not kkiepvvessau MKIV Supra 22 09-02-2008 01:55 AM
Repair or Swap? 82Dragon MKII Supra 4 08-28-2006 08:32 PM
Differential swap yooper61_99 MKII Supra 1 03-16-2005 11:26 PM
