Old 03-26-2011, 03:09 AM   #1
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
Default Steering damper/stabilizer?
What is up with the steering damper on the mk3? If they go bad, are they really a big deal? Or will it be better just to remove them all together? And why are they so hard to find? Any suspension tips are awesome, cuz thats the most important upgrade for my mk3, its very sluggish and floaty. Even with a new rack and pinion I haven't had a chance to put the control arm bushings on yet, but I got'em. Help my suspension!!!!!!!
supraheelfan is offline   Reply With Quote
Old 03-27-2011, 09:06 PM   #2
2genfun
2genfun is on a distinguished road
i replaced mine and didnt really notice much of a difference. the biggest improvement i got was replacing the rack bushings.
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 03-28-2011, 02:11 AM   #3
supraheelfan
Yea I changed out the steering rack bushings and I've got control arms next but I was wondering if I could just get rid of the steering stabilizers all together, ya know.
Old 03-28-2011, 04:11 PM   #4
btwilson86
Super Moderator
btwilson86's Avatar
The steering stabilizer is designed to help stop the steering wheel from jerking back and forth when the wheels go over rough or uneven surfaces (especially railroad tracks). I wouldn't recommend removing it.
Old 03-28-2011, 09:51 PM   #5
supraheelfan
Where should I buy some at? They are a hard find. Which is correct: Steering damper or Steering stabilizer? Some sites call them stabilizer and others dampers, and some are really expensive and some not, but I haven't seen any well known brands that make them yet. I know about all the main sites like Driftmotion, HPF, and supracarparts.
Old 03-28-2011, 11:20 PM   #6
907mge
907mge's Avatar
Magauto.com has it. I just searched "damper" and found it. But it is $158 and lists for $219. It does list as being the same part from 86 to 92 though so maybe you can try a used one.
Old 04-01-2011, 02:45 AM   #7
supraheelfan
Thanks a lot, that site is awesome. I can only find one at a time, not a pair. But oh well. I found some spacers that is suppose to give more steering angle, does anybody already have these on their suspension????????????????????????????????!!!!!!!! !!!!!!!!!!!!!!
Old 04-01-2011, 05:01 AM   #8
Are you talking about wheel spacers? Most people don't buy them for the purpose of changing the steering dynamics... just to fit larger tires or correct for a bad offset.
There is only one damper on the non-progressive power steering rack and the progressive racks do not have one at all.
Old 04-01-2011, 07:44 PM   #9
supraheelfan
The item description said it increases steering angle. Is that just for offset?
Old 04-01-2011, 09:39 PM   #10
907mge
907mge's Avatar
Are you searching in the section for oem toyota parts?
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
Power Steering cables wet (leak) question rjSupra MKIII Supra 2 09-20-2010 11:34 PM
Momo steering wheel , working horn and returning indicator stalk Gunnar MKIII Supra 0 03-28-2010 09:41 AM
Steering problems drmmr15 MKIII Supra 17 03-08-2007 09:32 PM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
