Old 03-15-2011, 05:44 PM   #1
JohnFurness
JohnFurness is on a distinguished road
Default Newbie has a question
Just bought a 87 MKiii and also new to treads, its runs great but just has a small oil leak. i checked where the oil is coming form and its coming from the transmission? now i know its not transmission fluid because its very thin. i removed the clutch cover and oil was drip out. anyone know how or why oil would be in the transmission?
JohnFurness is offline   Reply With Quote
Old 03-15-2011, 06:23 PM   #2
Ranma
Ranma's Avatar
Oh it could be anything from the valve cover gasket to a cracked head. My guy had a "mystery" leak, turned out to be a cracked head. Very close to the valve cover gasket.
Old 03-15-2011, 06:32 PM   #3
JohnFurness
But how would the oil get in the transmission housing ?
Old 03-15-2011, 06:49 PM   #4
Ranma
Ranma's Avatar
Mine was dripping from the tranny too. Changed out the rear main gaskets, the front gaskets, the valve cover gasket, etc. Then they used a dye and with the valve cover off discovered the leak. The 7mge and 7mgte have a problem with their head gaskets. After an overhaul and a rebuilt head, mine does not leak at all.
Not sure how mine found its way there but it did.
Old 03-15-2011, 09:24 PM   #5
Sonyps307
Look down behide the motor and look at the housing if it's all wet with oil then maybe valve covers or cracked head. If not then maybe it's the rear main.
Old 03-31-2011, 01:48 AM   #6
87hilux7mge
87hilux7mge's Avatar
agreed. i think its the rear main seal. check the rear of the motor, see if its coated with oil. if so, head gasket prolly. if just inside the bellhousing, rear main. as stated above
Old 04-01-2011, 03:34 PM   #7
El_supracabra
El_supracabra is on a distinguished road
rear main seal. check above the bell housing too.
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
Old 04-02-2011, 06:40 PM   #8
driftstar87
driftstar87 is on a distinguished road
My vote is for rear main seal. I wouldn't doubt if it needed a head gasket as well like mine did.
driftstar87 is offline   Reply With Quote
Newbie with a question! anarchy187 MKIII Supra 6 04-03-2010 04:26 PM
Newbie Question.. RonnyPockets MKIII Supra 3 05-26-2009 07:22 PM
newbie with question bluefever MKIII Supra 6 07-28-2008 12:24 PM
Newbie Question - Just bought 87 Supra Turbo NJ87SupraT Non-Generation Specific Questions 11 07-14-2008 02:01 AM
Super Newbie Question About Air Filters AssassinSM MKIII Supra 5 09-06-2006 04:55 AM
