Old 03-11-2011, 12:50 AM   #1
fantasma87
fantasma87's Avatar
Default need to know were to place the hose for...
were the hose from a aftermarket boost gauge goes on a turbo supra? I have everything installed already but the hose is out. thank you
ARMY STRONG !!
Old 03-11-2011, 02:50 AM   #2
"T" it off of the vacuum line which runs to the cruise control actuator (it comes from a vacuum port on the back of the intake plenum. Put the "T" in as close to that vacuum source as possible... the hose T's in a couple places. If you're not using the stock boost gauge you may just use the vacuum line which runs to the gauge's sensor by the cruise control actuator.
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
Cam breather hose Green7mgte MKIII Supra 0 10-17-2010 10:33 PM
Sm Vac Hose Under Accordian Hose Chromemoly MKIII Supra 3 07-03-2009 01:19 AM
