Old 02-28-2011, 10:21 AM   #1
itsjustsway
itsjustsway is on a distinguished road
Exclamation Crack!! (not the drug lol )
Horrible news/ needing advice... So I pulled the motor out of my mk3 turbo and noticed something bad.. There was a very small crack by 2 coolent channels by cylinder 2.. They don't appear 2 be leading into the cylinder how can I fix this? I was going to get the block pressure tested then weld the cracks it has then shave the block to ofcourse resurface and smooth it out.. Is this worth it? Or will the compression and force of the engine f-up the welds and moter if I take this route? .. Should I look into a 1jz swap??
itsjustsway is offline   Reply With Quote
Old 02-28-2011, 05:08 PM   #2
If the cracks are in the head, you could have it welded but it's probably going to be cheaper to just source another.
If the cracks are in the block, it's trash. You can't weld cast iron blocks with any reasonable reliability.... Not saying it can't be done but it usually fails gloriously in no time at all.
Old 02-28-2011, 05:17 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Please don't post in the MKIII FAQ. That's for frequently asked questions only. Thread moved to the MKIII general discussion forum.
Old 03-07-2011, 04:16 PM   #4
itsjustsway
Default Reply
So I would b better of buying another block or a whole new engine? The welds won't hold because there's 2 much pressure right
Old 03-08-2011, 03:40 AM   #5
Welding cast iron is a bitch, welding old cast iron can be hell and very unpredictable. There are a couple reasons why most welders will even tell you to forget it... I just can't remember the reasons. :P It's more a matter of penetration and inconsistent density. It can definitely be welded (I suppose that's up for argument but it's not my argument to make), but the couple people in that industry with whom I've spoken on the matter have all said that it's a waste of money and effort.
You'll usually have a horrible time finding a professional welder who will weld a cast iron manifold; Those are small and require less precision. It's not unlike when you crack the exhaust side of a turbo... it's trash.
If you can find someone who's willing to weld it the odds are that after the welding and all the milling and boring and flushing that it would still be cheaper to buy a used block and only do a mild rebuild.
Old 03-08-2011, 09:08 AM   #6
itsjustsway
Default Reply
Yea ur right .. Where can I find a block? Will it have to be used or is there a site I can order 1 from?
Old 03-08-2011, 12:16 PM   #7
Do you already know yours is bad?
As far as I recall they're no longer available new from Toyota. Used it the only option and there are a number of places you may acquire one. As I would be planning on rebuilding regardless of where it came from I'd look locally for one which I could inspect and measure myself. If you want one that's already rebuilt check the classified ads on the various Supra sites (I think someone posted here with a freshly rebuilt one recently). You could also try contacting Aaron at www.driftmotion.com to see if he has anything.
If you're planning on upgrading to forged pistons you may also use a GE block. You lose the oil squirters which are there to cool the stock cast pistons... not a big deal with forged though. You'll also need to have the block drilled for the oil return and supply for the turbo. If you go this route make sure you run a GTE oil pump and not the GE pump.
Old 03-15-2011, 05:09 AM   #8
itsjustsway
Exclamation Reply
So I took the block 2 a machine shop and they told me it was fine.. So I'm getting the block shaved and honed.. I want stock oversize 40 over pistons with rings.. Anyone have brand suggestions?
Old 03-15-2011, 05:53 AM   #9
Don't go 40 over unless you have to... on a turbo block bore it over as little as possible. That extra .15 liters (No, I didn't bother with the calculator for that number, but if you need we can) isn't going to gain you anything that's worth the extra meat between the cylinders... the 7M's cylinder walls are fairly thin as it is. I'd keep the walls meaty and add the whopping 1/2psi it'll take to make the same increase in power with a manual boost controller.
If you just want stock, Toyota or NPR are good. The NPR are available with a molybdenum coating too. Personally, at this point I'd put in something forged (never know how power hungry you'll feel in a couple months ).
ct-26 crack 907mge MKIII Supra 1 07-02-2010 04:37 PM
Timing Case Crack! teedoff00 MKIII Supra 1 10-20-2007 09:52 AM
