Old 02-27-2011, 10:53 PM   #1
Sonyps307
Default Rushing water sound on cold started ups
Hey guys I have a new rebuild 7mge with about 2000 miles on it. So when I start my car on a cold start up I hear a rushing water sound. then a few mins later it stops. Also I found a leak on the bottom of my water pump could that cause this. Thanks
Old 02-27-2011, 11:04 PM   #2
Is the rushing water sound kinda like a waterfall? If so, that's a sign of air in the cooling system. Usually a good long "burping" session can clear this up. Be sure when burping to get the nose of the car as high as possible.
And fix the leak, regardless of if it causes the problem you're noticing.
Old 02-27-2011, 11:13 PM   #3
Sonyps307
How do I Go about burping the system.
Old 02-28-2011, 01:03 AM   #4
It's discussed in the FAQ. I've never needed to do it but some people swear it's a must. It's not a Toyota standard procedure for the MKIII but it is for other vehicles (including the MR2, but that has a far more complex cooling system).
Removing the jiggle valve from the thermostat will help bleed the excess air more quickly with no ill side effect. Filling the coolant reservoir will help ensure no new air is introduced as the system is cooled (at least not from there).
You MUST fix the leak however you go about purging the extra air.
Old 02-28-2011, 01:28 AM   #5
Sonyps307
I was just worried because I heard that a BHG can cause this. But I dont know how it could be a BHG because it's a new gasket and I had them torque the head bolts to 75lb. The head was shaved also
Old 02-28-2011, 03:03 AM   #6
Any leak in the coolant system can cause this, not just a BHG.
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Occasional Clicking Sound (Blinker sound) coming from instrument cluster Mike87 MKIII Supra 8 08-26-2010 02:29 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 1 05-27-2008 03:23 AM
Waterfall sound on cold start! HELP! 88 MARK3 Non-Generation Specific Questions 7 06-29-2006 03:45 PM
