Old 02-23-2011, 03:26 PM   #1
Ranma
Ranma's Avatar
Talking Need Molding for my windows
My windows look like bleep due to the decayed molding. The dealer can not get them. Is it possible to get them redone? I like the black color against the red/purple.
Old 02-23-2011, 07:48 PM   #2
I'm a bit confused... you referring to the hard plastic and metal trim around all of the windows? That was only ever available in black. Sadly, yes, a lot of those pieces have been discontinued. Most you can buy new clips for and get them painted as you suggest.
Old 02-24-2011, 04:44 PM   #3
Ranma
Ranma's Avatar
Oh they have a black plastic cover, the inside looks chromed. Wonder if anyone could re coat them for me?
Old 02-24-2011, 05:49 PM   #4
Ok, gotcha. They were actually rubber coated and had a lip which created a sealing surface against the glass. You could get them powder coated or professionally painted for a very durable finish.
You may want to consider using a SMALL bead of silicone caulk to seal them to the glass to prevent moisture from getting under them... Hard to say, you don't want to create a moisture trap but you don't want to let rain get forced in under it at 50MPH. I would probably caulk the forward and upward facing edges and not the others. I'm serious about it being a small bead too, you're just trying to seal it up a bit, not glue it on.
Old 02-24-2011, 10:56 PM   #5
Ranma
Ranma's Avatar
wonders if anyone would restore the plastic?
89+ molding (trim) to 88 Supra Saiyan MKIII Supra 1 11-24-2010 09:42 AM
door molding coming off... MK3_supragirl Exterior , Interior, and Detailing 9 09-29-2010 10:22 AM
88 Molding Help afxzanac MKIII Supra 3 09-12-2008 07:31 AM
Tinted Windows Jason Van Dyk Non-Generation Specific Questions 6 01-14-2007 10:15 PM
