Old 02-13-2011, 02:16 AM   #1
looneytune_2004
looneytune_2004 is on a distinguished road
Default help with passing emissions
ok so i live in california and went to get my supra smogged( i hate it) and it failed the emissions part badly. and i also found out that my timing was advanced at 24 degrees BTDC. so my question is what is the best and quickest way to test my egr for correct operation and will my timing being that advanced cause me to fail also. any other ideas are welcome so i can pass this stupid test.
looneytune_2004 is offline   Reply With Quote
Old 02-13-2011, 02:17 AM   #2
looneytune_2004
i forgot i have a 7mge with a 5 speed
Old 02-13-2011, 02:25 AM   #3
24? advanced?! In what way did it fail? NOx? Did you remember the diagnostic jumper before testing the timing?
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=118
You should read through the diagnostics for the full system:
http://www.cygnusx1.net/Supra/Librar....aspx?S=EC&P=1
Old 02-13-2011, 02:37 AM   #4
looneytune_2004
yes it was and its at 24 degrees BTDC when it should be 10 degrees BTDC.
Old 02-13-2011, 04:33 AM   #5
Check your mechanical timing first. That much advance and you'd be overheating if something mechanical wasn't off too..... or you've got the god of all cooling systems.
Not Passing emission's :-( SDK MKIII Supra 14 04-18-2010 05:17 AM
emissions FYI ddmcse MKIII Supra 0 02-01-2008 12:34 PM
Went through Emissions today.... IHateHacks MKIII Supra 32 07-03-2007 07:31 PM
Emissions gorillaguy8 MKIII Supra 10 04-10-2007 12:33 AM
Emissions drmmr15 MKIII Supra 1 01-19-2007 04:09 PM
