Old 02-15-2011, 01:51 AM   #21
The VPC is a decent piece of hardware.... but it is OLD. By today's standards it's the MAFT Pro's handicapped brother who even gets beat up in the back of the short bus. It's great that it allows the removal of the KVAFM in favor of a speed/density setup, but the "one size fits all" pre-tuned ROM and very basic tweaking controls leave a LOT to be desired by today's standards. Honestly, at this point I'd step up to a MAFT Gen II or a MAFT Pro.... or go full standalone... but they're hell to learn in most cases.
Basic fuel controller are very easy to wire up, tuning takes practice and unless you're also installing a wideband you just have a shop do it for you.
You don't want to run that downpipe on the stock turbo unless you've welded in a dividing plate to separate the air spaces. Aftermarket turbos often have the housing cast so that the wastegate and the exducer's air flow is completely divided... not the case on the stock CT-26. Not doing so makes thins louder than they should be as the primary outlet is leaking out there too and it creates even more pressure that the wastegate actuator has to push against in order to open the gate. =
It does not matter that the outlet of the divorced wastegate pipe is open at the end. With a well flowing exhaust thet's just another matter of noise versus stealth... no performance gain, but no loss this time.
EDIT: There's also the MAP ECU. It's a unit comparable to the MAFT Pro... well the second generation of the MAP ECU is. Like the MAFT Pro, it lets you change over to a different type of air metering system (the MAFT Gen II does also but it lacks support for S/D and doesn't have a built in boost control function) and allows you to tune your fueling... I don't know if it offers wideband O2 integration, boost control or timing control. I have't used it, but in some circles it is VERY popular.
Old 02-15-2011, 03:27 AM   #22
jtown125
jtown125 is on a distinguished road
after much much much much much research today...
The neo still has my best interest.
what got me was this
"On MAF applications with open-air blowoff valves, there is a deceleration air correction feature that allows the tuner to compensate for the over-rich condition that occurs at throttle-off. By adjusting the MAF signal at throttle-off condition, the tuner can reduce the amount of fuel injected and prevent stalling."
my main issue right now.
The price range on all of the maft tuners are about the same as the neo, and they may have a few more feature than the neo. But I'm looking for something that gets the job done and looks good while doing it and the neo is a perfect example of that.
Features like being able to watch rpm's on the screen?
how badass is that.
I want someone to get in my car and say "nice gps"...and ill be like huh??
that aint gps....thats badass....
this is the link for the apexi neo if anyone else is interested
http://www.apexi-usa.com/products/De...id=5347&v=more
i also plan on doing the t61 upgrade from the ct26. The only part you have to buy along with it is an oil feed line. The stock drain feed will work. (correct if wrong)
The turbo doesn't pull as strong as it should, but holds strong when fully spooling. If i were to guess the hp the supra puts out right now I would guess around 250 or so, with the 1,000 dollars in mods I hope to hit 290 or 300 hp. Which is probably a long shot.
Oh and I went back and cancelled the order for the new offbrand bov, I fully believe the hks is doing what it needs to be doing and with it being recirculated it should be fine.
By the way, I put a couple of pics up on my profile if you want to take a look.
89 mkIII turbo supra stick black w/ maroon interior!!!
jtown125 is offline   Reply With Quote
Old 02-15-2011, 03:47 AM   #23
Function over fashion.... perhaps one of these days you'll think more of making power than dick waving.
how badass is that.
Pretty dumb since there's a gauge that's easier to read and in line with where you SHOULD be looking when driving. Man, you really bug the piss out of me... but you're nice enough so what the hell.
The MAFT series and the MAP ECU also allow you to switch to a less restrictive air metering system.... OR to DELETE the air flow meter altogether... now that's badass.
If one of my friends ever said that, they'd be walking home. Is there a new breed of stupid down there which just hasn't gotten this far yet?
250? At the crank maybe... you have no mods that are any significant power adders. If you'd read up more and take more time you should be able to get a lot more out of your car for that amount of money... of course that depends on how healthy your engine is. Fix that downpipe too.
Old 02-15-2011, 04:11 AM   #24
jtown125
People around here don't know alot about cars, I can tell you that much right now.
I do like that everyone comes to me with questions though...its quite sad that almost everything you need to know about cars you can find on the internet...all you have to do is read. (people are lazy, and I am too from time to time)
The performance rebuild kit that was put in the engine was rated at 260hp(with turbo at 4500rpm's) that is with .060 bore and a real nice set up on the twin cams and pistons, I don't think the crank was anything special. I DON'T believe its hitting anywhere close to that. It takes 7 seconds for a 0-60.
The engine is very healthy and can handle everything I throw at it.
(The exhaust has a divider welded on the turbo end)
I think I like "badass digital tach" over function cause im still young.
But the functions are close to being the same on all of the tuners, thats why there is so much competition over the items...
And the neo is a little easier to install in my personal opinion.
Now learning how to adjust things on it...thats another story.
Old 02-18-2011, 07:41 PM   #25
jtown125
For those who have been following this thread and may have similar problem. I ended up putting octane booster in the gas (routine for me) and the car still stalled, but did not die. I also ended up putting premium instead of mid-grade in this time, so I'm sure the combo had a big thing to do with it helping out.
I'm going to see if this will make any difference in a longer term and post my results back at a later time.
If this doesn't help your situation, revert back to previous suggestions.
Thanks!
Old 02-18-2011, 08:03 PM   #26
Be aware that the higher the octane the less power you make per unit of fuel. Higher octane fuel has mush lower kenetic energy and once you go beyond the ECU's ability to increase spark advance you lose both power and mileage.
I have no idea how that would fix your stall issue from a vented BOV... should choke up the engine just as much... You may have been experiencing an additional over-rich condition due to pinging which combined with the over-rich condition from the vented BOV.
Tags
5 speed mkiii 89 supra
1990 supra turbo problem. Rob1 MKIII Supra 5 04-12-2010 01:34 PM
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
