Old 01-30-2011, 04:36 AM   #1
amueller626
amueller626 is on a distinguished road
Default Are JDM 7MGE enginesw any good?
Does anyone have a recomendation on JDM engines?
amueller626 is offline   Reply With Quote
Old 01-30-2011, 04:56 AM   #2
907mge
907mge's Avatar
Its should be the same as any jdm motor. The only real difference is that the jdm 7mge will come without the egr because the jdm ecu is programmed to richer than usdm. So it is recommended to run a jdm ecu.
Old 01-31-2011, 02:38 AM   #3
91ma70
91ma70's Avatar
91ma70 is on a distinguished road
i thought the Jdm GEs have block off plates on the egr ports? You just need to change the emission components over and run the USDM ecu. then you call it a day. correct me if im wrong though
91ma70 is offline   Reply With Quote
Old 01-31-2011, 03:01 AM   #4
907mge
907mge's Avatar
It would makes sense for production but maybe cre will add on this?
Old 01-31-2011, 03:31 AM   #5
I don't know about the head. I know the intake plenum is cast differently, at least for some models; The material isn't even there for you to drill it out.
It seems the heads themselves are indeed drilled for EGR:
http://www.supramania.com/forums/sho...d-by-EFI-reset
There are a couple owners in there who mention their engines coming with block off plates on the head.
Fuel maps may not be the only difference but also the timing maps they're running.
Old 01-31-2011, 04:51 AM   #6
91ma70
91ma70's Avatar
I should give a call over to driftmotion and ask if its true; i was planning too anyway. ill report back when i do
Old 01-31-2011, 07:46 AM   #7
Yeah, Aaron should know off the top of his head. I'm pretty sure the ports are there though.
Old 02-05-2011, 05:01 AM   #8
91ma70
91ma70's Avatar
yup, the ports are there
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
86 MkIII 5 spd 7MGE for sale in Northern VA (Stafford/Fredericksburg area) ricangsxrdude MKIII Supra 0 11-12-2008 02:38 PM
