Old 01-22-2011, 02:20 AM   #1
1987mk3turbo
1987mk3turbo is on a distinguished road
Default 1987 passenger window motor... need help
i have a 1987 turbo auto, and the pass. window will not roll up all the way, i was wondering if anyone else has had this problem and if i need to change the motor what is the easiest way to get it out of the door?
1987mk3turbo is offline   Reply With Quote
Old 01-23-2011, 01:16 AM   #2
Replacing the motor isn't easy. It's just as difficult to pull the whole regulator out with the motor as it is to separate the two still inside the door. If it's rolling up half way easily then your problem is more likely the regulator.
Look at the wiring diagram and try jumping the motor with a 12V source for both up and down. Then try it with someone helping move the glass and to see if they can feel any notchiness to the movement. If they push/pull too hard is may hide the trouble area you're looking for. I'll found that the nylon rollers on the regulator often either flatten out or break off at this age, then the moving armature hangs up on the edge of the track anywhere that the lip has begun getting chewed up.
Passenger Power Window Problems JanusDuo Non-Generation Specific Questions 1 12-17-2008 08:11 PM
passenger window wont open tone loc MKIII Supra 3 06-25-2007 10:37 AM
some f*ck broke my passenger window D_Train MKIII Supra 9 04-29-2007 09:07 PM
Passenger side window kewlcoconut MKIII Supra 1 03-29-2006 07:58 AM
