Old 01-18-2011, 06:12 AM   #1
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
Default Ignition lock removal help
Ok I searched the forum's and could not find enough info on this
I can't figure out how to remove the cylinder lock
I have taken off the plastic casing behind the steering wheel but I have not removed the steering wheel....I'm hoping I don't have to???
I took off a tiny screw closest to the steering wheel
I push in the little pin on the top and the cylinder lock does not come out
What am I missing?? What am I doing wrong here?
supraturbo_mk3 is offline   Reply With Quote
Old 01-19-2011, 02:26 AM   #2
supraturbo_mk3
Really? No one knows how to remove a lock cylinder?
Old 01-19-2011, 02:35 AM   #3
Busted Knuckles
Busted Knuckles's Avatar
From the TSRM (knows most all), page SR-13 (Steering):
(a) Place ignition key at the ACC position.
(b) Push down the stop key (on top) with a thin rod, and pull out the key cylinder.
(c) Make sure the ignition key is in the ACC position.
(d) Install a new key cylinder.
Old 01-19-2011, 02:39 AM   #4
supraturbo_mk3
I have no key for the car that is why I ordered the new cylinder lock
Old 01-19-2011, 02:51 AM   #5
Busted Knuckles
You'll need to drill out the lock cylinder, then. This system was designed to prevent just what your trying to do. Anthing else and you risk damaging the steering column, which will be a harder job.
You could also check with a locksmith about picking the lock to get it to the ACC position. Then, the swap will be a snap. I just don't know what they will charge for the visit and pick.
The steering column collar is a sealed hunk of aluminum, and there is no other access the the lock cylinder.
Old 01-19-2011, 03:14 AM   #6
supraturbo_mk3
Thanks for the advice
Old 01-19-2011, 11:58 AM   #7
Busted Knuckles
I meant to add that you should only need to drill out the center tumbler section of the lock cylinder. Just to be able to remove the tumbler pins to get the cylinder to turn. Then use a screwdriver and rotate it to the ACC position, depress the pin, and out it comes.
Old 01-22-2011, 09:19 AM   #8
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
You could also try taking your VIN Number and your proof of ownership to the dealership and see if they can give you one. I have done that at a honda dealership before, key cost me $4 in 2007 (88 Honda Civic)
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
Ignition Synchronizer - what is it ??? cgreiner MKIII Supra 4 01-15-2009 08:39 PM
Question for someone who has actually seen the outside rear lock mechanism finaltable MKIII Supra 0 10-22-2007 02:44 PM
ignition lock cylinder suprabahamut Non-Generation Specific Questions 2 05-04-2007 03:29 PM
Ignition Ghost motosparky MKIII Supra 3 11-15-2006 03:45 PM
