Old 01-17-2011, 11:47 PM   #1
mauimale5799
mauimale5799 is on a distinguished road
Default Leaking oil
Hey everyone........... I need some help trying to figure out my problem on my 1989 Supra(non-turbo). The car seems to be leaking oil excessively, looks like mostly from the area behind the balancer. I have changes all gaskets and the cam seals also but it still leaking.
A friend said it could be a BHG causing the internal pressure that is forcing the oil to leak.
Any suggestions would be appreciated.
Mauimale5799
mauimale5799 is offline   Reply With Quote
Old 01-18-2011, 02:14 AM   #2
Sonyps307
If you had a BHG you would be burning oil and antifreeze is there bluish smoke or alot of white smoke coming out The exhaust and for the balancer you talking about the crank pulley
Old 01-18-2011, 02:32 AM   #3
mauimale5799
Yes, sorry its the crank pulley. No smoke to speak of but the antifreeze seems to be low constantly.
Old 01-18-2011, 03:01 AM   #4
907mge
907mge's Avatar
All I could think of is the crank seal or there is two places where toyota sealant goes between the head and the block at the front. And I don't believe a bhg will always result in burning coolant and oil since the hg can leak exterally also.
Old 01-18-2011, 04:26 AM   #5
mauimale5799
I think you might be right. If it is the sealant, is there a fix to put the sealant back on??
Leaking Oil 94TT MKIV Supra 7 10-29-2014 12:41 PM
leaking engine Ranma MKIII Supra 40 11-09-2010 03:18 PM
Oil Leaking Issue Jay633 MKIII Supra 3 06-28-2010 11:29 PM
Leaking Clutch eandjautoworks Non-Generation Specific Questions 0 07-03-2009 09:57 PM
Oil Is Leaking I Have Pics!! Need Help!! Ahmad88 Non-Generation Specific Questions 18 07-09-2006 03:56 PM
