Old 01-14-2011, 01:35 AM   #1
Mike322
Mike322 is on a distinguished road
Angry Heater Problem
Need Help ASAP:
At Start up, the heat on my 88 Supra n/t doesnt start working until 20 min after driving. It doesnt work after letting run for 20 min before driving. I changed the water pump. my overflow bottle (radiator) stays full. I know it shouldnt, but....... I empty the overflow bottle but it keeps filling up. I checked heater core, no leaks. NOT sure what the problem is...
I do smell radiator fluid while driving with window down, which is coming out of the overflow bottle. (noticed radiator fluid on bottom cover coming from overflow bottle.
Please Help!
Mike322 is offline   Reply With Quote
Old 01-16-2011, 05:25 PM   #2
Mike322
Default Radiator hose collapses with throttle.
Hello! A lot of useful info here. Well, I took radiator cap off, started up and put heat on full blast. Everything was going well, then the radiator fluid started coming out of radiator quite quickly, then it stopped. I saw that the radiator was low, so I put more fluid in, then it started coming out quickly again. Then i followed the same steps, by filling up... then i put radiator cap on. when I push the throttle, the top radiator hose pinches... hmmm what could that be?????
HEEEEEEEEEEEEEEEELP!
Old 01-16-2011, 05:58 PM   #3
Green7mgte
Supra Forum Moderator
thermostat. rad cap. simple things id check first.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 01-16-2011, 08:18 PM   #4
I suspect s blockage may be to blame... blockages and bad thermostats are common culprits for problems like this. Old hoses may collapse too as there is a natural vacuum in the system. I'd start with testing/replacing the thermostat.
BTW, your first posts were both in moderated sections intended for different purposes. Please check where you're posting before you do so. This is the correct section.
7MGE Throttle Body Mar1 MKIII Supra 10 12-06-2010 07:38 AM
lost of power at full throttle?? peedamonkee MKII Supra 4 01-08-2008 05:50 AM
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
Throttle response f00g00 MKIII Supra 1 04-13-2006 12:57 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
