Old 01-15-2011, 08:29 AM   #1
looneytune_2004
looneytune_2004 is on a distinguished road
Question cant stop high idle
ok so i finally got my motor swap from auto tranny to manuel tranny shell done, but now i started it and it has a high idle it goes from 1400 rpm up to 2000 rpm, all my vacuum lines are good, my timing is perfect, it never had a idle issue when it was in the old shell it never had any issue so now im lost for thought. HELP.
Oh its a 7mge, and I moved my engine into the shell that already had the ecu and manual transmission. Now originally my 7mge came from an automatic tranny. All I did was just drop it in n hook it up. But now I can't get the idle to go down at all.
looneytune_2004 is offline   Reply With Quote
Old 01-16-2011, 04:42 PM   #2
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
Check the idle circuit on your Throttle Position Sensor, also check, clean, or replace your Idle Speed Control, as they have a tendency to stick when left sitting for a while
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
Old 03-29-2011, 05:36 PM   #3
pandrade
pandrade is on a distinguished road
i had the same exact problem on my 87 gte and i also repalced all the vacume lines. i went to the junk yard and found the idle control valve of a non turbo supra from 86, the housings are diffrent but the electronic part (the black part on top) are exactly the same so i swaped them and it idles just fine now
pandrade is offline   Reply With Quote
Old 03-29-2011, 06:48 PM   #4
Travis89Turbo
Travis89Turbo's Avatar
Idle control valve or the wiring to it
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 03-29-2011, 07:05 PM   #5
a400tool
a400tool's Avatar
a400tool is on a distinguished road
Idle Control Valve (ICV)
http://motors.shop.ebay.com/i.html?_...506.m270.l1311
a400tool is offline   Reply With Quote
high idle mikeoc1 MKIII Supra 0 07-08-2009 03:22 AM
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
High idle nickvash0104 MKIII Supra 21 07-13-2006 05:14 AM
