Old 01-10-2011, 05:34 PM   #1
mike91
mike91 is on a distinguished road
Question need help loosing wieght!!!
hey guys new to the forum. have a 91 supra turbo, engine sieriously only has about 57,000 miles on in. i wanted to go full race with it and gut the car. But that plan was shut down real quick when i ran it by the wife!Lol! anyways she said to keep all the seats in, i still wana gut it but was wondering if anyone knew about any kinda light replacement rear seats. even if its something i have to make. i basically want the car to be track ready but still a daily driver. if any one has pics of there supra gutted i really like to see them for some ideas. thanks
mike91 is offline   Reply With Quote
Old 01-10-2011, 05:47 PM   #2
This link may get you an idea on what's worth removing and what's not. I'd say one of the best things you can do would be to find replacement front seats (especially the drivers seat)
Old 01-10-2011, 06:11 PM   #3
mike91
hey thanks that was very helpful. so in gutting the car i was going to either use a thin like cieling carpet or even the rubberized spray to help absorb all the noise that will come,and also with removing the rear wiper and antenna inyour opinion should i cover up the holes with a metal patch weld or go the easy way and just use some body putty filler?
Old 01-10-2011, 06:28 PM   #4
lawl i ran a bead of silicone down my antenna
Old 01-11-2011, 12:40 AM   #5
907mge
907mge's Avatar
Nice job destroying a low milage 91. Which is one of only 3600 sold in the US. Doing what you what will make it worthless. Losing rotation mass has been proven to be much more effective than staionary weight. I'd do flywheel, driveshaft and wheels before gutting an interior to make a heavy car only slightly less heavy. The majority of the weight that can be easily removed is in the spare tire and the drivers seat. I've had my interior apart before and there wasn't that much weight to it really. The car has a heavy chassis.
Old 01-11-2011, 12:52 AM   #6
the antenna mast was busted so i removed it and shoved a piece of dried silicone inside of the hole and capped it with a piece of rubber grommet
completely removable if i ever decide to put a new one in. but between my ipod and satellite radio i probably wont.
im a firm believer in keeping things as stock looking as possible.
thought you were talking to me there for a second.
10 pound rotational mass is equal to 100 pound stationary or so ive read.
100 pounds ='s 1 second in the 1/4
Old 01-11-2011, 04:16 AM   #7
907mge
907mge's Avatar
No I just hate to see a nice supra interior destroyed just so the weight can be dropped by a 100 lbs. And with the rotation mass I have seen as people write as high as 1lbs Rotational = 20lbs Stationary or a low as 1lbs Rotational =1.4lbs Stationary
Old 01-11-2011, 07:07 AM   #8
100lbs is not anywhere near equal to 1 second in a quarter mile... I've seen people gut the holy hell out of these beasts, swap out as much as possible with carbon fiber and aluminum and still only end up with a 3200lb sloth (but hey, it used to be 3500)..... they still sucked in the quarter mile and was now louder and more uncomfortable to drive than the lack of gains made it worth. If you want better mileage... try to lighten it... if you want more speed get a bigger turbo and throw more power at it.
The stock seats are HEAVY.... either get aftermarkets or seats from another car and build your own brackets, track down a JDM Recaro set, or just swap out the electric LH seat with a LH seat from a JDM MKIII (so you'll have a matching non-power set).
A lighter one-piece drive shaft will help, but not just due to the lowered rotating mass but because of the reduced frictional loss in the center carrier bearing and U joint. Get steel if you go this route it handles the stresses much better than aluminum and won't grenade nearly as soon. Any one-piece drive shafts should be checked every few thousand miles for cracks or swelling near the center.
Old 01-11-2011, 06:36 PM   #9
thanks for the correction. ill stop saying the 1 second thing. and yell at the person I heard it from.
Old 01-12-2011, 02:58 AM   #10
mike91
geez! life is way to short to put prices on things. whats the worth in having things if your not going to use it.tell ya what if any of you want this supra and keep it stock i'll sell it to you. i'll pick up another gut it to the bones and blow up the motor and it will just be another day. i want to enjoy my life full speed and die young! LOL
Tags
need to lose weight!
Power to wieght ratio ecko Non-Generation Specific Questions 1 02-10-2008 09:54 PM
Loosing fluids.. AbsoluteSpeed MKIII Supra 6 08-18-2007 08:08 AM
Oil wieght for turbo motors Caliturbo88 Non-Generation Specific Questions 7 01-31-2007 04:21 AM
