Old 12-29-2010, 09:46 PM   #1
MA70 Owner
MA70 Owner is on a distinguished road
Exclamation high idle ???
im not to sure whats goning on because it happened before. i changed the alternator, battary,plugs, wires, distributor and the aternator fuse. and it worked fine. but its happening again. ive tested everything and it works all good. so i was hoping someone here would direct me in the right way so i dont have to spend an insane amout in a shop..
MA70 Owner is offline   Reply With Quote
Old 12-30-2010, 12:23 AM   #2
Sonyps307
Check for vacuum leaks or leaks in the intake pipes after the mass air
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
annoying high pitch squeal at idle oowee623 MKIII Supra 2 06-04-2007 03:02 AM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
High idle nickvash0104 MKIII Supra 21 07-13-2006 05:14 AM
