Old 12-21-2010, 06:57 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Default Lexus AFM upgrade ??Wait or toss it on??
So if I take my 7mgte supra that has the following mods..
3'' cat back
AEM intake
So if I was to say~.. What if I did the Lexus AFM Upgrade????
Would that be ok or will I be throwing the whole system into shams?
I just need the Lexus AFM to do the mod right? Is it a direct swap?
Old 12-21-2010, 09:16 AM   #2
mkiiisupra
Direct drop in yes...
Without fuel pump and 550cc injectors you will run lean. It basically allows more unmetered air into your engine.
1990 Toyota Supra Turbo A/T
Old 12-21-2010, 01:58 PM   #3
^ agreed. you could bypass the 550cc and get an safc but you would need a AFR gauge to see how much to increase or decrease
Old 12-21-2010, 04:29 PM   #4
You don't need an upgraded pump for this mod, the stock one flows more than enough. You DO need to be 100% sure yours is in good shape (so might as well replace it with a better one anyway). As mkiiisupra said, you must install the injectors first or prior to the AFM or you will run lean at WOT.
What is the Ultimate Economical 7GTE-M Upgrade??? Bruno Molly MKIII Supra 0 05-10-2009 04:30 PM
Lexus 550 injectors and afm upgrade help plz flnbobpogoman MKIII Supra 3 08-05-2006 08:51 PM
Lexus AFM question? rnoswal MKIII Supra 13 04-20-2006 06:34 AM
