Old 12-20-2010, 11:41 PM   #1
frostburn
frostburn is on a distinguished road
Default Power Problem!
Hey, I have an 89 turbo and for some reason when i was trying to turn over my car (it always takes a few times to start in the cold) I lost all power, So i automatically thought it was the 100Amp ALT fuse under the hood so i went to canadian tire and got a new one i replaced it and the interior likes worked i tried to crank over the car it made a noice like trying to start the ignition while it was already turned over for a split second and then all power died again. So i was thinking it may have blown that fuse again and i got another new one and replaced it again and their is still no power. Help please? P.S The battery is less than a year old was never over powering anything and no lights where ever left on. Thanks.
Frostburn.
frostburn is offline   Reply With Quote
Old 12-21-2010, 12:40 AM   #2
Sonyps307
Check the alt. If it's bad and it's not recharging the battery and maybe the last time u drove it. It was running off the battery and killed it check volts of battery too if it's lower then 10 volts the car won't start I think
Old 12-21-2010, 12:48 AM   #3
frostburn
well thats the thing... when i changed the fuse the first time it gave me interior power and it was strong before i tried to crank it over i checked the over head lights the head lights and all the beep was strong and the battery is fairly new... and when i tried to turn it over it made the ignition noise... so i know it was trying to turn before everything died. and if its the alt than why did i have full power back from a simple fuse if the battery was ran dry from running no alt?.
Old 02-26-2011, 07:55 AM   #4
mark
mark is on a distinguished road
Red face
Even i got an 1989 Toyota Supra with turbo engine, which has started making noise. pretty annoying and hard to find. Sounds like a steering pump. Please help me to narrow it down.
Frostburn.
mark is offline   Reply With Quote
Power steering problem chinesedawn MKIII Supra 0 02-14-2010 11:20 PM
Power steering problem JOEYP3RD Non-Generation Specific Questions 1 06-05-2009 05:19 AM
Interesting power loss problem! stssa MKIII Supra 4 01-13-2009 04:54 PM
power steering problem 3.0trd MKIII Supra 12 06-24-2008 01:17 PM
light and power problem bigdoggbmx MKIII Supra 3 12-05-2006 07:00 PM
