Old 12-08-2010, 12:29 AM   #1
Natesupra66
Natesupra66 is on a distinguished road
Default 11sec
How much hp and mods is needed to make a 7mgte low11 sec
Natesupra66 is offline   Reply With Quote
Old 12-09-2010, 11:20 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Is that 0 to 100 MPH ? Cant remember of the top of my head, but 0 to 60 is about 6 to 7 seconds
Old 12-09-2010, 11:56 PM   #3
worm611
worm611 is on a distinguished road
Low 11 second car is relative to many things, just because you have the HP doesn't mean your chasis is setup right to put the power to the ground.
Are you going to loose any weight or keep it as a stock street car also? Curb weight can play a large part in this as well.
So I guess we need to know exactly what you want your car to be, how streetable, what you are and do not want to change, then maybe we can give you a guestimate.
worm611 is offline   Reply With Quote
Old 12-10-2010, 01:38 AM   #4
Natesupra66
11pm flywheel ,cometic head gasket, walbro fuel pump stage 2 clutch 3 in not cats exhaust his dragger muffler Msd fuel regulator,Lexus maf manual boost controller,k&n airfliter parts that are not installed injectors what size t 70 turbo power house map ecu and is the ecu capable of getting me in the 11s
Old 12-10-2010, 02:06 AM   #5
907mge
907mge's Avatar
I'm not a expert on this but with the hp you are going to need you probably should start by building up the motor. I belive to get the time you want is going to require at least 500hp.
