-   -   Weird problem! Need HELP!! (http://www.toyota-supra.info/forums/mkiii-supra/18259-weird-problem-need-help.html)
Jllahman 01-04-2011 02:45 PM
Bump! Anyone have an idea?
Green7mgte 01-06-2011 12:40 AM
you have no fuel at your rail?
its either a fuel pressure problem or your entering limp mode. does your check engine light come on while this is happening?
hows your wires.. hows your spark plugs?
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=21
Jllahman 01-06-2011 06:39 AM
Its getting fuel to the rail, I don't know if its a fuel pressure issue though. That was my first thought.. but I don't have a gauge on the line so idk. What is limp mode?
Sonyps307 01-06-2011 11:54 PM
Limp mode is when ur ecu retards ur timing and makes it run rich so you don't blow the motor mine was in limp mode just fixed it today my knock sensor wire broke had to rewire it but I was getting code 52
