Old 11-23-2010, 05:29 PM   #1
mkiiisupra
Default Engine rebuild
Everything is stripped off my engine and the head is ready to be pulled. Its about ready to go off to the machine shope and i had some questions related to that.
MHG with only the head milled?
What else should I have the machine shop do while they have the head?
Ultimate goal is 450whp I have all the supporting external mods for this in place/or ready to install.
1990 Toyota Supra Turbo A/T
Old 11-23-2010, 06:39 PM   #2
Ranma
Ranma's Avatar
They can pressure check it, looking for cracks. You might as well have the valves done while you are at it.
Old 11-23-2010, 11:30 PM   #3
mkiiisupra
Valves done?
Liked cleaned and checked or replaced?
Old 11-24-2010, 01:52 AM   #4
907mge
907mge's Avatar
Cleaned, valves and seats reground. It helps to restore compression. Are you rebuilding the block also?
Old 11-24-2010, 03:10 AM   #5
mkiiisupra
no, id like to do just the head.
Ive done all my own mechanical work on this car and learned how from this forum and others. Have no previous mechanical background so pulling the engine alone is not something i want to do at this point.
Plus if i pull the block i may as well spend the money and have whole thing rebuilt with upgraded parts.
Old 11-24-2010, 03:59 AM   #6
907mge
907mge's Avatar
I'll amit that I don't know that much about building for high hp but if you are trying to more than double the hp from stock I would make sure the bottom end is order. I mean the 7mgte came stock with 220hp at the crank, so 450hp at the wheels is alot when you account for a 15% power loss for the drivetrain . And when I did my hg I realized how little is left to pull the motor once the head is off.
Old 11-24-2010, 06:51 AM   #7
mkiiisupra
been looking for a guide with pics on block removal to get a better idea of what else is involved past the head removal all ive found is http://www.supramania.com/forums/sho...-49-easy-steps.
7MGE Engine rebuild oregonjoe MKIII Supra 69 03-23-2010 02:12 AM
Toyota Supra 1992 Rebuild engine? ngmc11 Non-Generation Specific Questions 3 08-25-2009 07:47 PM
PLEASE help newbee with engine rebuild canadian mole MKIII Supra 4 06-17-2007 01:01 AM
1988 supra engine rebuild 1988Suprakid MKIII Supra 5 06-07-2006 09:07 PM
New Engine Or Rebuild Help ! ! ! ! ! DarkRaiderz MKIII Supra 5 01-23-2006 01:21 AM
