Old 11-13-2010, 04:07 AM   #1
Sonyps307
Default W58
I have A 89 supra with the w58 and the front seal is leaking so I took it to a transmission shop and they said that the rubber seharbor rock hard and cut a grove in the shaft so they said they will try to sand it down some to help it seal and new front and rear seals for 150$ or replace the shaft which is 850$ so I found a w58 out of a 87 supra but mine has a little box with a wire coming out of the top of the tranny and a wire coming out the side which is the backup lights switch right and the 87 w58 doesn't have the top wire. So what is it for.
Old 11-13-2010, 04:56 AM   #2
bioskyline
bioskyline is on a distinguished road
quite possibly its the abs sensor. as your have the 89 abs was standard from then on, for the 87-88 it was an option. a pic of would help
87 silver turbo targa, bone ass stock (for now)
bioskyline is offline   Reply With Quote
Old 11-13-2010, 11:40 PM   #3
ABS was still only an option in '89... and later years in the US. And you're right. It'd be for the rear ABS speed sensor.
