Closed Thread
Old 11-11-2010, 07:18 AM   #1
Babyface
Babyface's Avatar
Babyface is on a distinguished road
Default MkIII Wheels.
Does anyone know if I can fit a 15x7 rim running 195/50/15's on all four corners in a 1989 turbo? The stock rims are 16's I believe, but I don't know if they will clear the brake rotors.
Thanks for the replies.
Babyface is offline
Old 11-11-2010, 09:26 AM   #2
91ma70
91ma70's Avatar
91ma70 is on a distinguished road
Why get 15's?
91ma70 is offline
Old 11-11-2010, 10:06 AM   #3
fantasma87
fantasma87's Avatar
hey man they are going to look ugly like hell, especialy if running with 50 low profile tires. the supra have a lot of clearence between the fender and the center hub. i will concider something bigger or unless planning on bring it down to the floor " low rider". i believe the rotors are between 13 inches. good luck with it , GET BIGGER RIMSSSSSSS
ARMY STRONG !!
fantasma87 is offline
Old 11-11-2010, 03:50 PM   #4
907mge
907mge's Avatar
Way to small. Even if they do fit over the calipers.
http://www.miata.net/garage/tirecalc.html
907mge is offline
Old 11-11-2010, 05:16 PM   #5
SOME will fit fine and others won't in all cases the caliper is quite close to the inside of the wheel.
There are some good reasons for running 15's... bigger sidewall = more cushion while driving and some reduced wear on suspension components. Also, they're great for snow/autumn tires as hitting a massive pothole of sliding into a curb is less likely to destroy the rim.
cre is offline
Old 11-11-2010, 08:55 PM   #6
907mge
907mge's Avatar
Except with that size of tire he will have less sidewall then with the stock size. It would need to be a 195 65 15 just to maintain the factory height.
907mge is offline
Old 11-11-2010, 09:10 PM   #7
As you've just pointed out in your own post, smaller tire = more sidewall area if the circumference is equal. Same reason why I can run 17's with a much lower profile tire on a car that came stock with 15's.
cre is offline
Old 11-11-2010, 10:13 PM   #8
907mge
907mge's Avatar
I think I worded it wrong. I meant with that size of tire he will be running a tire with an overall diameter that is much too small versus stock. With that size there is no benefit to running a 15 rim.
907mge is offline
Old 11-11-2010, 10:37 PM   #9
If he's looking for a ghetto look then who cares. If he's looking to run them in a general capacity it's fine, just needs a different profile tire... as you've stated... Why are you still going on about this?!
cre is offline
Old 11-12-2010, 03:41 AM   #10
bioskyline
its a try and fit, might lucks out, though finding the right offset to clear the calipers might be tricky, a steel wheel being thinner might clear, but in my experiance no 15 inch rim i tried to stick on my car would clear without a spacer plate, ive even had some 16's not clear.
you can run a spacer plate, but then you need longer studs. as for tire size,i personally wouldnt run the 195's, there a lil narrow and id go for a 205 or 215 (we had 225/50VR16's stock). or just drive carefully, as the smaller tire probably has a lower weight capacity, as its designed for a smaller and lighter car than the mk3.
bioskyline is offline
Closed Thread
Will these Wheels Fit and be close to flush on my MKIII TripleC MKIII Supra 3 12-10-2009 02:05 AM
MKIV TT Wheels fit MKIII? 87supraturbo MKIII Supra 3 01-10-2006 11:26 PM
