Does anyone know if an Acura Legend has the same lug pattern as my 89 supra?
its the same bolt pattern, but if there the stock 15's i doubt they will clear the brakes. if there aftermarket 16, 17, 18 or bigger, should fit no problem
most 15's will not clear the front calipers
Ok, it's been covered... it's hit and miss and you're going to have to flat out try any that you're considering buying on first.
Simple enough? Thread closed. |
| All times are GMT. The time now is 07:42 PM. |
