Old 11-07-2010, 10:52 PM   #1
AutoPirate
AutoPirate is on a distinguished road
Default No Injector Pulse
88 7mge. Built motor, bored out, ported, etc. Toss it in and no injector pulse.
I own a repair/performance shop so I have plenty of resources at hand. Here's the details:
Has spark
Has compression
Electronic fuel control system good(Main relay, circuit opening relay, solenoid resistor, cold start injector, temp sensor, pump relay and resistor, AFM, TPS, all are good).
No pulse from ECU, no fuel pump prime or run (jumped b+ to fp, pump is good).
Engine runs when ether pumped into intake(ran this way for 45 minutes to check all other systems, everything good)
Harness is fine, all circuits verified.
Thoughts?
AutoPirate is offline   Reply With Quote
Old 11-08-2010, 04:37 PM   #2
AutoPirate
wow, looks like I might be on my own
Old 11-08-2010, 08:55 PM   #3
Ranma
Ranma's Avatar
Talking
Probably a broken wire someplace.
Old 11-08-2010, 09:07 PM   #4
89ST
89ST is on a distinguished road
I would think that the circuit in the ecu that sends the pulse to the injectors has had its day.
89ST is offline   Reply With Quote
Old 11-09-2010, 12:00 AM   #5
CHUCKABOON
CHUCKABOON's Avatar
CHUCKABOON is on a distinguished road
Default No pulse
First thing I look for is check eng light operation. My rule is No check eng. lite NO START. Could you have left the ground lug off ? (Bolts to intake)
Let me know,I'll help you...I've got the factory manual.
(I do this stuff for a living too, since '67)
Chuckaboon
CHUCKABOON is offline   Reply With Quote
Old 11-09-2010, 04:12 AM   #6
zby67
zby67's Avatar
zby67 is on a distinguished road
Chuckaboon
ware did you get a factory manual?
1986.5 MA70 7M-GE
1987 MA70 7M-GE
zby67 is offline   Reply With Quote
Old 11-09-2010, 05:37 AM   #7
btwilson86
Super Moderator
btwilson86's Avatar
Anyone can get the factory manual in a pdf off of this website in the FAQ, also there is the one that's accessible online.
To get a paper copy, last time I checked (about 4 years ago) you could still get them new from Toyota. They also pop up on eBay from time to time.
Old 11-09-2010, 09:05 AM   #8
CHUCKABOON
CHUCKABOON's Avatar
Default factory manual
I confiscated mine when I worked at a Toyota Dealer many tears ago.
