Old 11-04-2010, 09:22 PM   #1
Cameroonski
Cameroonski is on a distinguished road
Default I Need ONE Piston!
So everything was going smoothly in my rebuild when my last piston fell of my work bench. After seeing the dent in it, i proceeded to through things at the wall, and then calmed down to clean up and look for a replacement part. Made my day really.
Where can i order just one piston? Everything on my rebuild is standard size. (1986.5 7mge by the way). Rings, bore, blah blah are all good for standard so i was just re-using my pistons. I really would like to not have to spend 200 more dollars on a piston set. So please are there any websites that sell single, stock pistons?
Thanks!
Cameroonski is offline   Reply With Quote
Old 11-04-2010, 09:29 PM   #2
bioskyline
want a used one? free + shipping its still in the engine so id have to pull
Old 11-04-2010, 09:31 PM   #3
Cameroonski
Maybe! If i can't find a new one i will definately take you up on that offer. How many miles are on it?
Old 11-04-2010, 09:35 PM   #4
bioskyline
just over 200,000 kms but i got 6 to choose from so if you do ill pull you nicest looking one.
the engine was running but the cam seals are shot and it keeps slipping the timing belt so it wont run for more than 5 min before its need a re-time. its just a parts car anyways.
Old 11-04-2010, 10:17 PM   #5
Cameroonski
Awesome, ill send you an email.
Old 11-05-2010, 04:56 PM   #6
You can get a set of NPR pistons with rings from these guys on eBay: eBay Store - Mizumo Auto Engine Parts Honda Toyota Lexus Nissan Car: Head Gasket Set They're OEM spec, so not awesome, but good enough for anything you'd plan on putting a stock piston through.
I've bought from them a couple times without problem.
MKIV Wilwood GIANT W6A 6 piston 14.25 inch brake kit ARZ Arizona Performance 0 08-25-2010 06:00 PM
piston rings which ones to get? Clorox9 MKIII Supra 0 06-14-2009 04:35 PM
1jz & 2jz Piston Rings joolhamdi MKIII Supra 4 04-14-2006 02:44 AM
