Old 11-04-2010, 02:10 AM   #1
johnvin
johnvin is on a distinguished road
Default exhaust NEED HELP
is this all i need for exhaust system ? like down pipe and every thing to compeat it ?
johnvin is offline   Reply With Quote
Old 11-04-2010, 03:22 AM   #2
Minymurf
Minymurf is on a distinguished road
you need a catalytic converter aswell. unless your gonna use your stock one.
Minymurf is offline   Reply With Quote
Old 11-04-2010, 03:33 AM   #3
bioskyline
bioskyline is on a distinguished road
the downpipe is not shown so id assume it done have one
87 silver turbo targa, bone ass stock (for now)
bioskyline is offline   Reply With Quote
Old 11-04-2010, 03:34 AM   #4
Minymurf
no resonator either. its pretty much a half length straight pipe atm
Old 11-04-2010, 07:34 AM   #5
bioskyline
ok yes this will go from the rear of the car to where the cat was mounted. it looks like it will bolt the the megan racing d/p but might need a 3 inch cat in the middle or a custom adapter to delete the cat if you dont have air care
thats a really loud system, so check local noise laws to, casue it may be classed as "race only"
Old 11-04-2010, 04:58 PM   #6
MJG
MJG's Avatar
That appears to be one of the "cat back" systems on Ebay. If so, you may wish to check with the vendor and see if this system bolts directly to the DP.
Most of those Ebay systems are intended for "off road use only". The fact that the system includes the muffler insert, which is designed to be used to "quiet" the exhaust on the street and be removed when at the track, suggests it will eliminate the second cat.
As mentioned, without a resonator, it will be loud. If you run the muffler insert, you will find it very restrictive and it will negate the free flow characteristic of the 3" pipe.
The two systems I have seen from Ebay (not the system pictured) are a good value for the cost. Both eliminated the second cat, had resonators, and are loud enough to turn heads under acceleration.
Old 11-05-2010, 03:20 PM   #7
johnvin
what are the two systems that you found on ebay ?
Old 11-05-2010, 06:55 PM   #8
MJG
MJG's Avatar
I could find only one of the ehaust systems. Attached are two photo's of the system sold by "ETD Motors" on ebay.
$348.00 shipped.
ID:	3574   Click image for larger version
Old 11-05-2010, 06:59 PM   #9
MJG
MJG's Avatar
I should have mentioned, the ETD system is the same system sold by Driftmotion.com, just a few $ less.
Mk3 exhaust upgrade for under $50.00!!! batmmannn MKIII Supra 12 06-04-2010 01:52 AM
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
Does the exhaust manifold need to come off to replace head gasket? BillW MKIII Supra 1 10-02-2009 12:19 AM
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
