Old 09-11-2005, 06:44 PM   #1
Ron90Turbo
Ron90Turbo is on a distinguished road
Default water leaking from A/C inside car
When I run my A/C in my 90Turbo, I get a lot of water leaking inside on the passenger side. Anyone know how extensive of work it'd be to fix or unclog the drain? Thanks.
Ron
90 Supra Turbo (slightly modded)
99 BMW M3
Ron90Turbo is offline   Reply With Quote
Old 09-11-2005, 09:40 PM   #2
The drain tube is probably plugged, or the rubber tube that passes thru the firewall is missing. Its about finger round, and 6" long. Look for it down below the evap canister. You can usually remove it from the passenger foot area and blow it out.
Old 09-12-2005, 04:31 AM   #3
mazzer
mazzer's Avatar
mazzer is on a distinguished road
Default evaporator drain
i usualy never take them out.i've always had good luck with a piece of spedometer cable and blow gun with the extended nozzle. watch yourself so you dont get a facefull of water and debris..
3"elbow back,massaged head and manifolds. other minor mods....
mazzer is offline   Reply With Quote
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 1 05-27-2008 03:23 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 0 05-26-2008 09:27 AM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
