Old 10-31-2010, 02:45 PM   #1
cfurlan
cfurlan is on a distinguished road
Default Help after rebuild 7mgte
Well after two weeks I finally put my engine back in. The car started but it runs like crap, almost like a misfire or something. I'm guessing it is the timing but I didn't have a timing light. I turned the crank by hand and everything lines up when the crank is at 0. I believe it's not suppose to be on zero so could this be my problem possibly?
cfurlan is offline   Reply With Quote
Old 11-01-2010, 07:48 PM   #2
89ST
89ST is on a distinguished road
yes, your problem is almost certainly timing. a timing gun is rather cheap and you'll certainly want to get one. I'm sure it will fix all your problems.
89ST is offline   Reply With Quote
Old 11-01-2010, 07:51 PM   #3
bioskyline
bioskyline is on a distinguished road
yeah you cam sensor need to be adjusted via a timing light. you can guess at it (adjust it while engine is running till it runs smooth) but for the 50 bucks for a timing light you know for sure.
87 silver turbo targa, bone ass stock (for now)
bioskyline is offline   Reply With Quote
Old 11-01-2010, 08:53 PM   #4
cfurlan
I'm getting ready to try it in a few, I did try to do it by ear but didn't do anything. I also bought some ngk's so I'm gonna put those in first.
Old 11-01-2010, 10:45 PM   #5
Sonyps307
I just had my motor rebuild and the guys that build it had my distributor off a tooth or two and I had trouble getting it fire up but it did start and ran shitty had to pull out the distributor and fix it know it runs great and get a timing light it makes it so much easier To tune
Old 11-01-2010, 11:36 PM   #6
cfurlan
Was that on a 7mge, mine is a gte. Well I changed the spark plugs and checked the timing and it ran a little better but it still sounds like its misfiring. I found one air leak on the back side of the intake. It is a steel hose that bolts to the intake. Its a very small air leak so I don't think it would be causing it to idle down to 400 rpm's and killing it. I really wish I could figure this out.
Old 11-02-2010, 03:15 AM   #7
MJG
MJG's Avatar
Having not experienced the results first hand, have you checked your crank is not 180 degrees out from your cams?
I would doubt the engine would start, however, if it did???
Old 11-02-2010, 03:33 AM   #8
btwilson86
Super Moderator
btwilson86's Avatar
It shouldn't, I've made that mistake before. Before anything, FIX YOUR AIR LEAK. Also, did you set your timing with the jumper wire in the diagnostic box? If you didn't, your timing will still not be properly set.
Old 11-02-2010, 03:51 AM   #9
MJG
MJG's Avatar
Thank you for the correction Mr. Wilson. good to note.
Old 11-02-2010, 07:57 AM   #10
cfurlan
Yeah I did check the timing with the jumper and it was at 10. It doesn't matter where I turn the CPS it still rins rough. I'll fix the air leak later today after work. One more note, it runs the same as before when I overheated the engine if that helps. It ran great before overheating though. The cause of overheating was due to a worn hose that blew out. Thanks all
7mgte rebuild questions bradenman1 MKIII Supra 0 05-27-2010 03:36 PM
7mgte performance motor rebuild tommy951 Non-Generation Specific Questions 1 11-02-2008 01:58 AM
88 7mgte Rebuild SocalSupra Non-Generation Specific Questions 1 09-26-2008 06:57 PM
Should i REbuild 7mgte or just buy 1 WhiteTurboZ89 Show n Tell 2 02-07-2008 01:09 PM
