Old 10-20-2010, 01:44 PM   #1
cfurlan
cfurlan is on a distinguished road
Default 88 supra turbo ticking from top end
I just got the car yesterday with 85000 miles on the body and 700 miles on a fresh rebuild with receipts. The guy said that there were aftermarket lifter springs which he thinks is cause the ticking. It speeds up when revving the engine but does not affect the performance at all. I'm new to the supra world but am not new to tinkering with cars. I know these don't have push rods but from previous experiences it sounds identical to that. Also the oil pressure is around 20 psi at 3000 rpms if that makes any differences. He also had it bored over 020. Any advice would be great. Thanks
cfurlan is offline   Reply With Quote
Old 10-20-2010, 05:51 PM   #2
Sonyps307
I just had my motor rebuild and I have the same tapping as you does the tapping stop or get quieter after it's been run about 15-20 mins like mine. my tapping started about 300-400 miles after the rebuild and is about up to 1000 miles now mine just started burning oil the other day and I found out that they torqued my head bolts to 58 lbs and not 70lbs so I'm thinking with the new motor the head gasket shrinks a bit and now is looser more and now the head gasket it slapping between the head and block so I'm taking it to the rebuild shop and let them look at I will let u know what happens
Old 10-20-2010, 06:43 PM   #3
cfurlan
Well mine ticks the same amount after it warms up. I'm hoping mine is just an unseated valve but please let me know what they say.
Old 10-20-2010, 06:47 PM   #4
Sonyps307
So urs keeping tapping after warming up and has it start burning oil Also check ur header and spark plugs they can cause tapping to that sounds the same and I will let you know what the shop finds
Old 10-21-2010, 03:00 AM   #5
907mge
907mge's Avatar
It could just be the injectors, they are noisy on toyotas. Even the ones on my 2zzge are like that too. Thats why the ticking gets quicker with more rpm. Alot of people confuse them with valve noise. It could be what you are hearing.
Old 10-21-2010, 03:13 AM   #6
cfurlan
I'm 98% sure it's not the injectors. This is definitely louder than what an injector could do. But I will still check each injector.
Old 10-21-2010, 03:17 AM   #7
907mge
907mge's Avatar
If you can't identifiy it by ear then you can always take off the cam covers and check the cam clearances.
Old 10-21-2010, 03:58 AM   #8
cfurlan
I know how to tear it down, but exactly how do I measure the clearances? Thanks for all your help
Old 10-21-2010, 04:05 AM   #9
907mge
907mge's Avatar
With a feeler gauge you can measure the gap between the lobe and the shim ontop of the bucket that sits over the valve stem. Here is the link to the TSRM.
http://www.cygnusx1.net/Supra/Librar....aspx?S=EM&P=7
Old 10-21-2010, 04:23 AM   #10
cfurlan
Ok I'll try to get a feeler gauge tomorrow and try that.
Information about non turbo Supra Jimbo_2JZ Non-Generation Specific Questions 3 02-20-2009 10:13 PM
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
