Old 10-15-2010, 02:47 AM   #1
Sonyps307
Default Little tapping when start up
So when I first start up my non turbo I hear a little tapping going on but it stops about 5 mins of running and will not start tapping again intill the car has sat for a while could this be a header or exhaust leak or maybe a bad lifter Or does a bad lifter always tap as the car is running
Old 10-17-2010, 09:17 PM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
You could take the heat shields off and look for black carbon tracks around the exhaust manifold. FelPro makes a nice thick beefy exhaust gasket. The exhaust nuts are notorious for rusting to the stud and then you end up stripping the stud in the head instead of tightening the nut. If you want to, apply a small amount of penetrating fluid to the nuts and let it soak awhile. Try loosening a quarter of a turn and see if they move together or separately. If they are frozen together try backing out the stud and nut together then soak in penetrating oil. Break them loose by grabbing the middle of the stud where there are no threads with a pair of vice grips. You may have to alternate using a torch and a cleaning with a wire brush then adding more penetrating oil it comes loose. When they separate clean the stud threads with a wire brush. Keep track of which end was in the head. Use a jam nut to reinstall the stud. This is easier done with the exhaust manifold off. Then you can tighten 2 exhaust manifold nuts facing each other temporarily to drive the stud in. Again, its aluminum so don't overtighten. Worst-case scenario is you have a rotten stud hole or threads are pulled. A repair consists of drilling out the hole and tapping new threads and using a "Heli coil" repair. Apply small amount of anti-sieze compound and torque than nuts gradually using the pattern in the repair manual and torque to spec.
Is your oil old or thined out? Use the proper viscosity for the temperature range are going to be in encountering. I also replace a quart of my oil with Lucas oil additive which is quite thick and a lot like STP but not that thick. The oil pressure with 20% lucas oil is a little bit higher than otherwise. Another thing that can make a ticking sound is a loose spark plug. Make sure they are torqued down to 13 - 16 ft. lbs. Another thing you can check is the valve lash. Since Supras do not have hydraulic valves, they are adjusted using a wafer shim that rides under the camshaft for each valve. It's best to have a manual to follow the procedure to get the measurement correct. Valve lash clearance measurement is accomplished using flat feeler gauges on a cold engine. Excessive clearance here can cause a ticking sound. If you're going to replace a shim, it's helpful to have the S shaped specialty tool to hold the valve opened when removing the wafer shim and a mechanic's magnet. You don't want to scratch the camshaft face with screwdriver or get your finger pinched. You also need either micrometer or vernier caliper (and know how to use one) to get a measurement of the thickness of the wafer in the cases where there is excessive clearance and want to calculate the replacement shim to order. If your cheap, like me, you can play musical chairs with the shims. Find one that's tight on the spec. and see if you can swap the loose one to bring them both in spec (or at least closer than they were). The thickness of the shim and the valve lash is the total distance. I have even sanded the backside of shims with worn emery paper on a flat surface to shave off one or two thousandths. Just be sure the sanded side stays down and not riding against the camshaft. Hopefully it's not a connecting rod bearing or wrist pin. Thicker oil could buy you a little time. Carbon buildup can cause preignition taping but that's more likely on a hot engine. I use redline SI-1 gas additive (Amazon.com). Try one bottle full in a tank of gas for a quick cleanup and then to 2.5 oz. per tank there after. It comes in a 15 ounce bottle.
Good luck
Old 10-17-2010, 10:45 PM   #3
Green7mgte
Supra Forum Moderator
+1 for the post..
good stuf there bru
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 10-17-2010, 11:39 PM   #4
Sonyps307
All the valves and lashes should be to specs the motor was just rebuild With all new pistons, rods, bearing and the head was redone to. Like a month or so ago just has alittle over 1000 miles on it and just had it first oil change about 2weeks ago and the tapping started around 300-400 miles after the build But I just found out they Torque they head bolts to 58lbs Could this cause any thing and I will check the spark plugs and header bolts tomarrow
Old 10-17-2010, 11:43 PM   #5
Sonyps307
And It just started to burn alittle oil but I think thats ok for a new motor with new rings right
Old 10-18-2010, 12:13 AM   #6
907mge
907mge's Avatar
It can also lose a little bit into the pcv. When I had my intake apart, all parts where coated with oil on the inside.
Old 10-24-2010, 10:20 PM   #7
aamt07
aamt07 is on a distinguished road
I had the same problem with my supra. When you crank it up it made a tapping noise sounded like aluminum and metal slapping together. After i took the engine out and dissected it i found out that it was a bad rod and a bad piston. The engine oil rest at the bottom and is rather thick, when you start it up and let it run a little while it heats up and thins out making it lubricate all internal components. Thats the reason why it stops knocking. I hope yours isnt as bad as mine once was! its a pain in the rear. also one other thing you could do is take off the oil cap I think you can see cam gears from there shine a light and see if you have any wear as far as scratches or chips taken out of cams.
aamt07 is offline   Reply With Quote
Old 10-24-2010, 11:08 PM   #8
Sonyps307
Yea but my motor is new just rebuild with new piston and rods and bearings so they did something wrong on the build
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
