Old 10-11-2010, 05:05 PM   #1
breadmk3
breadmk3 is on a distinguished road
Default help me!
somthing wrong with my turbo... i wen n check it they say it my turbo but i think it the o2 sensor... anybody? also sumthing wron with my brake. wen i step on it i have go to all the way to make it grab. but it only grabs alittle. i change the brake pump n the brakes r still good.
breadmk3 is offline   Reply With Quote
Old 10-11-2010, 06:59 PM   #2
fantasma87
fantasma87's Avatar
about the brakes , did you bleed the lines? make sure theres no air at all inside the lines. about the turbo , i cant help for now . i dont know much about them.
ARMY STRONG !!
Old 10-11-2010, 10:32 PM   #3
breadmk3
I did that already
Old 10-11-2010, 10:39 PM   #4
fantasma87
fantasma87's Avatar
maybe one of the calipers its not working properly, find someone to help you and put the jack wheel by wheel and verify that the calipers are working while the other person step on the pedal. spin the wheel and check. Good luck. Q
ARMY STRONG !!
Old 10-12-2010, 10:45 PM   #5
breadmk3
How do u check if there in he brake line
Old 10-14-2010, 03:19 PM   #6
89ST
89ST is on a distinguished road
If your break pedal has to be pushed to the floor to receive any substantial braking force than you have air in your brake lines. Maybe you should bleed them again, and make sure you're doing it properly.
What are the symptoms of your turbo not working? not boosting at all? lower boost than usual? Then maybe i can help.
89ST is offline   Reply With Quote
Old 10-17-2010, 08:17 AM   #7
breadmk3
i do not know. it seem that i am over boosting... i have a greddy profec the inlet is in the wastegate and the out ish tpo the turbo
Old 10-17-2010, 12:35 PM   #8
did you bleed all 4 of your brakes...
if it is not done properly you will have bad bad brakes.
Old 10-17-2010, 10:41 PM   #9
Green7mgte
Supra Forum Moderator
you also bleed from fruthest away to closest.. soo.. RR/ LR / RF/ Lf
dipshit.
how descriptive.
Your parents must be so proud..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 10-18-2010, 12:40 AM   #10
thanks for saying something. peoples lack to at least explain wtf there talking about, like really.. your just going too get the same effort in the response....
