Old 10-08-2010, 04:40 AM   #1
dave
dave is on a distinguished road
Default 7mgte or other turbo engine
88 supra turbo 5-speed targa with sems. please give your advice,,,i bought this car for 800.00 the motor runs but is knocking bad soooo, will a jdm engine from ebaymotors be what I should do, and replace 7mgte or upgrade to 1 or 2jz....i can get the motor out myself but I don't want to mess with alot of changes... any help will be great....
dave is offline   Reply With Quote
Old 10-08-2010, 07:16 AM   #2
If you don't want to mess with a lot of changes, I'd stick with the 7MGTE and get your current one rebuilt. To me, that's your best option.
You can get a jdm engine, but not knowing how the engine was ran and what kind of care was given to it by it's previous owners means it'll be a gamble to drop into your car without rebuilding it as well.
Going 1JZ or 2JZ will not happen without having to do alot of changes, unless you have a shop do it for you. And then you'll be several grand into this project.
Old 10-08-2010, 02:39 PM   #3
Metaphysico
Metaphysico is on a distinguished road
I grabbed a jdm motor tore it down checked internals for wear, replaced every gasket in the engine, new water pump, t-belt, thermostat and a bunch of other stuff, so after the price of the motor, usually $1000 or so you are looking at adding another $500 plus labor to get it up and going. I did not replace the valve seals and I just had to go back and replace them. They were very very bad. So $1500 min plus labor, if you have to pay someone it will be high. But normally if you don't have at least $4000 don't plan on doing a 2j or 1j swap.
Metaphysico is offline   Reply With Quote
Old 10-26-2010, 08:44 PM   #4
Gamn82
Gamn82 is on a distinguished road
Default 7mgte
I have an 88 toyota supra targa top, turbo charged. I am parting it out. Only thing wrong is small dent in drivers side in front of door. Engine runs fine, turbo works. Email at gwlg82@yahoo.com, if interested in parts. Live in maryland if you want to drive it before engine comes out.
Gamn82 is offline   Reply With Quote
New turbo for 7MGTE Stupra MKIII Supra 4 09-13-2008 11:22 PM
