Old 09-28-2010, 01:30 AM   #1
89ST
89ST is on a distinguished road
Default Mk3 supra turbo won't start after running fine.
Hi everyone, I'm new and I apologize now If I'm doing something wrong.
My car is an 89 Supra turbo LHD. The car was running, backed it out of my driveway, went to ingage first and the car shut off. I thought possible i'd stalled it, however it would not restart.
So...
- I didn't run out of gas!
- I have no diagnostic codes popping up.
- if i supply the fuel pump with power if runs.
- fuel pump relay when triggered sounds as though it's functioning.
- car is sparking because when cranked it back fires every so often.
Now when i turn the car to the on position the fuel pump does not seem to prime. nor do i hear it or the fuel pump relay working when i'm the cranking the vehicle. I'm thinking possibly the ecu has bit the dust.
Any other suggestions? Thank you
89ST is offline   Reply With Quote
Old 10-04-2010, 07:29 PM   #2
89ST
i'm not sure why no one is responding?
Any advice is much appreciated.
Old 10-04-2010, 08:24 PM   #3
fantasma87
fantasma87's Avatar
does the engine spins? can you smell fuel on the engine bay? and about nobody responding get used to it , i placed a post last week and no one responded yet so , relax and enjoy the ride!! Q
ARMY STRONG !!
Old 10-04-2010, 09:27 PM   #4
89ST
yes the engine does turnover, the starter is relatively new. I'll check on the fuel smell thing. I haven't noticed it. Not an overwhelming smell anyway.
Thanks for the advice
Old 10-04-2010, 10:04 PM   #5
fantasma87
fantasma87's Avatar
i don`t know too much about this engines but anything can happen , verify the timming belt or any blown fuse. good luck . Q
ARMY STRONG !!
Old 10-05-2010, 03:42 AM   #6
Well, if you're sparking that means your timing belt is at least intact (because your exhaust camshaft is spinning). The fuel pump should not prime until your cranking the engine over.
I assume the problem occurred because of how suddenly the engine stopped spinning (from stalling it out). Is your cam position sensor tight? You should not be able to move it at all by hand.
Please Help!!!! MK3 Supra wont start Slinks2000 MKIII Supra 1 05-06-2010 03:37 PM
My Supra Turbo will not start GMKC1234 MKIII Supra 4 08-25-2006 10:06 PM
