Old 09-24-2010, 03:32 PM   #1
Sinistral
Sinistral is on a distinguished road
Default Help diagnosing clutch problem
The other day when I engaged/disengaged the clutch backing out of a parking lot, I heard a noise that sounded like scraping and the faint smell of burning rubber. It made the noise all the way home each time I shifted, though the smell only came when I was taking off from a stand still. The car itself ran fine - no problems shifting or engaging/disengaging the clutch, just the noise and the occasional smell.
Not sure what it is; I'm more curious as to whether this will get worse the more I drive or if something just got misaligned. Any and all help is greatly appreciated.
Sinistral is offline   Reply With Quote
Old 09-26-2010, 02:18 AM   #2
How responsive is the clutch, same feel as usual? any slipping? smell like burnt braked or more like oil? Have you checked the belts?
Old 09-27-2010, 04:31 PM   #3
Sinistral
Clutch still works as it always has minus the noise. As for the smell, the best way I can describe it is burnt rubber. Haven't checked the belts; I'm not particularly mechanically-inclined, so I can't say I'd know what I was looking for.
Old 09-28-2010, 08:09 AM   #4
Busted Knuckles
Busted Knuckles's Avatar
Burnt rubber has me more inclined to look for a tire or an accessory belt. Fried clutch is a distinctive smell, similar to brakes burning. You will never mistaken a burnt clutch for a 'rubber burning' smell. Look under the hood, then check the inside sidewalls of your tires. Look for scuffing marks and melted rubber. An overheated belt or scuffed tire bears marks that are easy to spot.
Old 09-28-2010, 09:01 PM   #5
89ST
89ST is on a distinguished road
Another thought,
Not saying you don't know what burning rubber smells like. but if your hand brake line got ceased and or one your rear calipers is ceased that would make up for the scrapping metallic noise you hear, and the burning smell. Also when you shift and the engine noise momentarily decreases you can once again hear the scrapping noise of the stuck break until you're back on the throttle.
89ST is offline   Reply With Quote
clutch pedal problem StonecoreTx MKIII Supra 6 01-07-2010 07:19 PM
Weird clutch problem wbeams MKII Supra 11 09-18-2008 05:36 AM
Clutch Problem coltskicker MKIII Supra 3 11-29-2007 11:44 AM
Clutch Problem carfanatic89 MKIII Supra 2 07-31-2007 07:43 PM
clutch problem blazinrola80 MKIII Supra 0 01-26-2005 06:20 PM
