Old 09-23-2010, 03:30 AM   #1
2.5RHDsupra
2.5RHDsupra's Avatar
2.5RHDsupra is on a distinguished road
Default Sick of It
Ok, My 1991 supra its being retarded. I regret buying it, but i need to fix.
I can floor it Under "D" but it feels like it doesnt want to go. so i took it to a transmission shop. they replaced the solenoids because thats what the codes said. they also replaced the transmission pump. about a month later Its doing the same thing it flashes codes 62 and 64. can some one please please please help me fix this! It will drive fine under L,2 and R but not D( the important one)
2.5RHDsupra is offline   Reply With Quote
Old 09-23-2010, 04:30 AM   #2
I've never worked much with automatic transmissions but the first thing I can think of that would also account for intermittent problems and diagnostic codes is the computer. Have you tried swapping in a different ECT? And speed sensor error from the ECU? Speedometer still moving?
Old 09-23-2010, 04:55 AM   #3
2.5RHDsupra
speedometer does jiggles up to about fifty. and i never thought about switching the ECT. would the switch buy the shifter that say. power and manual do anything. because i know that is broken
Old 09-24-2010, 01:16 AM   #4
The ECT gets one of it's two speed signals from the speedometer... if the speedometer is messed up I'd bet the ECT isn't going to behave. The TPS is another thing to check. I'm not sure what switch you refer to , but generally if any of the switches were turning on and off at random you'd have problems. Look at the wiring for the switch (it it's not the gear selection switch) and try bypassing it and going for a short drive.
Is there anything else wrong with the car?
Old 10-03-2010, 01:33 AM   #5
2.5RHDsupra
no nothing else it wrong with the car.
and what is TPS.? and where can i find it.
im new to supras so.
Old 10-03-2010, 03:26 AM   #6
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=100
Old 10-03-2010, 08:03 PM   #7
You r screen name just hit me... so I presume you have a 1JZ. Might want to mention that or put it in your signature. The link I posted is from the Toyota Service and Repair Manual for the USDM MKIII which was never available with the 1JZ. For a 1JZ manual you'll do well to check the UK and AUS websites. A link has probably been posted here in the past, or you could also check the swaps section over at supramania.com.... I know it's been posted there.
TPS - Throttle Position Sensor, probably 99% of EFI equipped cars have them. They're always (well, almost) on the throttle body. And TPS is the standard acronym, nothing specific to Toyota.
Sick Vid For All You Mkiii Lovers tyron MKIII Supra 7 06-27-2010 03:13 PM
sick supra Mikek MKIII Supra 1 03-23-2007 01:25 AM
i need help! my baby'z sick :( 89supra323 MKIII Supra 5 02-27-2006 09:24 PM
My Supra is sick, please help me! 89_Supra MKIII Supra 3 09-06-2005 01:42 AM
