Old 12-07-2004, 03:17 AM   #1
Supra Guestkakapoopie
Guest
Posts: n/a
ok...a giveaway supra, but i wanna make sure the engine inst crap
what is a good compression for a 7mge and what is crap? keeping in mind it is free...but i dont want to take something that is total crap.
also another question is what are the best value upgrades for the 7mge?
can it be turbocharged?
sorry for the newbieness
Old 12-07-2004, 11:23 AM   #2
Jester
Jester is on a distinguished road
up grades.... it depends on what u wanna do. showroom, racing, burnout.... u need to decide what the car is for then research the parts. yes it can be turbo'd. compression... anything under 9:1 is not so good. 10:1, 10.5:1 11:1 are much better... if its a giveaway, something will be wrong. no one gives away a perfectly good working car that is only 13 years old. it was probably in an accident or has internal damage
Jester is offline   Reply With Quote
Old 12-08-2004, 12:51 AM   #3
mm
Guest
Posts: n/a
well, its actually my aunt's car and she just bought an RX8 so she needs to get rid of the supra. its rusty form the seasalt so im sure thats not too good
i want the car for drifting/ dialy driver
Old 12-08-2004, 11:28 AM   #4
Jester
oh ok...
wow u have a cool aunt. my aunt drives a stationwagon. youll mainly need suspension mods then
Old 12-08-2004, 06:37 PM   #5
k
Guest
Posts: n/a
Originally posted by Jester@Dec 8 2004, 11:28 AM
oh ok...
what suspension mods??srry im total newbie
Old 12-09-2004, 02:12 AM   #6
Jester
before u do any mods - my advice to you would be to
1) find the soonest local drift event
2) get some used 15 or 16'' v6 wheels with tires to learn on
3) go to the event see how you like it, find what you wanna improve on and go from there.
i suggest doing some of the fluid swaps before you push it though. Tranny, Radiator, Differential, Engine Oils all swapped. Take your car to the track and spin it around for awhile, you shouldn't do any handling mods at first, learn to drift stock. it will make you a better driver.
then id do some research and find out what your car can do better, whether you have oversteer, understeer, bodyroll, etc then id look into parts that will eliminate any problems u are having
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
