Old 09-28-2010, 04:44 AM   #51
btwilson86
Super Moderator
btwilson86's Avatar
OP, you said that you replaced the big wire that goes to the starter (i'm assuming that this is the one that you said only had 400mv); what is the voltage at the wire now? This wire, at all times (regardless of if the key is on, clutch is pressed, alarm is armed), should always read the same voltage of the battery. Period. It is a direct connection to the battery, there is nothing inline that can cut the power to it.
Do this in the order listed below:
  1. You said it's a new battery, have you verified that it still has a charge? Use your volt meter and check the voltage of the battery between the positive and negative posts. If this isn't around 12 volts, charge the battery.
  2. Check the voltage of the big wire at the starter to the negative post. If this is not the same as #1, inspect the positive battery terminal. If it is, continue to #3
  3. Check the voltage of the big wire at the starter to a clean spot on the engine block. Voltage here should still be the same as the above two bullets. If it is not, inspect your negative battery cable for damage, corrosion, or poor connection at each end.
If your voltage is still the same, then your problem lies in the circuit leading to the small wire on the starter, or within the starter itself. As Travis89Turbo said, just because it's new doesn't mean it's good. All parts have a percentage of defects out the box, yours could be one of them.
Old 09-28-2010, 06:40 AM   #52
ochowdero
this website should help,
since were arguing about what it is and dont have very much information on whats going on you need to read this..
it gives your common questions or problems and gives you the answers..
if you found the problem on the troubleshooting list (the link) and the trouble shoot didnt work then come back to us with the correct problem and the best information you can give us...
heres the link
http://www.samarins.com/diagnose/index.html#click
the area you need to look at on this page is in the middle..
starting with "The starter won't crank" - thru - "battery problems"
this info should help you..
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 10-02-2010, 01:19 AM   #53
Conga1991
Conga1991 is on a distinguished road
Okay, it was just ba wiring in the harness. I replaced it wit a manual harness and got it to turn over but no spark now I checked to see if there was power getting to the coil pack (book said 12 volts) and there was no power 0 Volts. I checked the igniter and there wa 11 volts getting to it. So could the problem be the coil pack??
Conga1991 is offline   Reply With Quote
Old 10-02-2010, 01:42 AM   #54
Travis89Turbo
Travis89Turbo's Avatar
So u just bypassed the harness correct? U need to make sure that ignition signal gets to the ecu as well
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 10-02-2010, 02:06 AM   #55
Conga1991
No, I just swapped in the manual harness and it turned over. Just no starting all the way.
Old 10-02-2010, 10:03 AM   #56
ochowdero
read that link i gave you..
you replaced the harness,
soo the website should tell you what to do..
i really want turbo
Old 10-04-2010, 04:07 PM   #57
t12tninja
t12tninja is on a distinguished road
i would say check your grounds cause i had the same issue but i didnt do a swap but it sounds like my problem check all the grounds and mine was the ground in the steering colum
t12tninja is offline   Reply With Quote
Old 10-06-2010, 03:55 AM   #58
Conga1991
Where would the ground be for the steering column?
also does the cam position sensor have to be timed? from what I was told you just put it in and make sure the bolt that holds it is in the middle??
Old 10-06-2010, 04:04 AM   #59
btwilson86
Super Moderator
btwilson86's Avatar
Yes, you have to time the CPS. No, you can't just drop it in. You have to line the gear up with the mark on the CPS, when you install it you have to compensate for the several degrees the whole thing is going to turn. Here is a link to the TSRM on how to PROPERLY install the CPS. Be sure you follow that last step (setting the ignition timing).
Old 10-20-2010, 12:10 AM   #60
Conga1991
So I finaly got to it today, tried the ignition timing and still nothing! Any oter suggestions?? if not, time to call a mechanic.
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
headlights wont turn off after swap 89supra884 MKIII Supra 7 04-19-2010 03:24 AM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
