Old 09-10-2010, 12:33 AM   #21
ochowdero
ive already listed what is required for the auto to w58 swap. and all this info should be posted in the FAQ.
so I'm sure it is possible for you to scroll up or go to the FAQ and start researching, because im done doing it for you.
i detect hostility >:P
im just trying to be 100% about this,
thanks tho
Old 09-10-2010, 12:38 AM   #22
yes i should have included!
if your really motivated to do so, you can set up the wires so that the car will only start when the clutch is pushed in, just like a standard.
but personally i like having the switch under my hood, that way whan i park my car some where i don't want to, i know its not gona get stolen.
WAY too obvious when you go to activate it. You want it in the cabin somewhere that you can reach and touch without it looking out of the ordinary.... like a push button switch hidden under the shift boot.
Old 09-10-2010, 01:11 AM   #23
thanks tho
You're raising a few people's blood pressure...
A large amount of what you're looking for a is very commonly discussed and very easy to locate... why should they have to keep digging up stuff from this forum just to repeat it? A little self-sufficience will get you in a lot better with the locals. Just a tip.
Old 09-10-2010, 01:22 AM   #24
ochowdero
very true,
ill keep the look out for the parts,
i guess what im asking for is, i dont wanna miss parts...
soo heres my list so far
w58 tranny
bellhousing...(is that for a particular motor?)
clutch master cyl
slave master
clutch and brake pedals, stick shifter
my auto ecu would work fine am i correct?
and anything else?
i looked and people listed parts but seemed to small for the actually swap, so i just wanna be sure, and with your guys knowledge(more then mine) i can make that happen
Old 09-10-2010, 04:12 AM   #25
Yes, bell housing is both engine and transmission specific. The bell housing from either a 7M equipped Cressida or N/A Supra will work. You also need a 7M-GE flywheel and I believe the starter needs to be changed... IIRC that is. The front half of the drive shaft is different. You'll need a shifter, boot and I think the interior bezel is different.
Old 09-10-2010, 08:52 AM   #26
ochowdero
yeah i just talk to my master mechanic who will be doing the swap,
he knows a guy that sells the flywheel, clutch master and acouple other peices i cant remember...
hope to get the tranny, but not gonna do the swap for a while haha
Tags
mk111 mkiii mk3 tranny
Engine harness question between auto and manual gambit1982 MKIV Supra 4 05-25-2010 05:34 AM
auto to manual tranny swap sd88supra MKIII Supra 10 11-24-2009 06:25 AM
Question about switching an auto tranny with a manual one TehEl1te MKIII Supra 2 10-21-2009 09:45 PM
Difficulty of changing tranny from auto to manual vas85 MKIII Supra 2 06-03-2006 08:30 AM
