Old 09-07-2010, 10:08 AM   #1
ochowdero
Default ooh boy, auto to manual tranny swap question.
i want my 87 supra (N/A) to be manual.
whats the best route to take.
there is no way to trade the car for a 5 speed, or buy a project 5 speed either.
so what can i do?
this is a really big issue for me..
can i take a transmission and motor out of a similar car? if so would it be worth it?
any help please, like ive said this is a really big issue for me...thanks
Old 09-07-2010, 10:40 AM   #2
ochowdero
bump bump!
Old 09-07-2010, 11:49 PM   #3
Sonyps307
You can swap a 5 speed in but you need all the parts like transmission, clutch, clutch pedals, master and slave and hard lines And you have to do something else to the wiring I think to
Old 09-08-2010, 12:01 AM   #4
ochowdero
i know that, but nowadays you can seldomly get ahold of a supra 5 speed tranny...
is there any other car i can take the tranny out of?
Old 09-08-2010, 12:21 AM   #5
Sonyps307
Toyota Cressida some years had 7mge in them
Old 09-08-2010, 12:28 AM   #6
you need:
w58 5 speed transmission
front half of drive shaft from a 5speed
clutch and brake pedals from a 5 speed
hard line that goes from master to slave clutch cylinders
master and slave clutch cylinders (i would buy new)
Clutch and flywheel for w58
what would be nice:
radiator from a 5 speed.
all rubber boots to protect from dirt and leather shifter boot.
and of course you need to trick your neutral safety start switch:
remove this from your auto tranny and plug the wires back into your engine harness in the P Park position, or the car will never start.
good luck.
did i miss anything??
Old 09-08-2010, 12:47 AM   #7
ochowdero
thanks. where can i find the wh8?
easiest
haha
this was good thank you,
i new what i needed but miss acouple things.
should i find a junk cressida and take the tranny out of that?
Old 09-08-2010, 12:54 AM   #8
most 5speed cressida aorund my area have been scrapped for there 5 speeds and 5m and 7m engines.
i would honestly just try and buy a super rusty 5 speed supra same year as yours and that way you see it all come off, and can put it all back on without problems
Old 09-08-2010, 12:55 AM   #9
ochowdero
Default sorry
sorry i didnt make this clear..
i know what i need, well some what, so pointer in that would be good
what im trying to really ask is whats the easiest way to get my hands ahold of a 5 speed tranny and most or all the parts?
sorry for that, bad on my part for not clarifying my true question
Old 09-08-2010, 01:01 AM   #10
its you who is not understanding.
"buy a rusty supra for its 5 speed tranny"
that way you get EVERYTHING not just a tranny. you get the pedals... cylinders...hardline... clutch... not to mention all the dirt boots and leather boot...
Tags
mk111 mkiii mk3 tranny
Engine harness question between auto and manual gambit1982 MKIV Supra 4 05-25-2010 05:34 AM
auto to manual tranny swap sd88supra MKIII Supra 10 11-24-2009 06:25 AM
Question about switching an auto tranny with a manual one TehEl1te MKIII Supra 2 10-21-2009 09:45 PM
Difficulty of changing tranny from auto to manual vas85 MKIII Supra 2 06-03-2006 08:30 AM
